Damsel in distress! Need help w/ engine stuff!
I have a '66 F100 V8 Cruise O'Matic that's in need of a new engine (was told that 2 cylinders aren't firing & that I have "rod knock"--my mechanic, whom I trust, told me this). My question is this: What kind of engine do I look for? 289? 302? "short", "long", "small", "big", etc. What will fit? I think I need a "small, long block" but I have no clue really. . .
Also--I'd like to upgrade to power steering & brakes, as well as replace the transmission.
Obviously, I'm not capable of doing the work myself so I'm trying to locate someone in my area who can do the work (my mechanic is too busy to take on this project and he says that Ford's aren't his forte) but I'd like to start searching for the needed parts ASAP. . . . .
Help! Thanks!
Secondly, you are right, no dumb questions.
Let's see.. If you have two cylinders not firing, you will have knock. Do you want to try and solve the non-firing problem first, or just spend lots of $$ to replace a motor. If the motor is stock to the truck, you have a 352 "FE family" (old school big block) V8. We would need to determine if it is factory to the truck. If the intake manifold extends 1/3 under the valve covers and the plugs point to the middle of the heads // \\ , then it is an "FE family" motor. The 352 was put into 65-67 trucks, then they went 360/390. The good news is that if you want direct replacement, a remanned 390 long block (motor with heads) can fit right back in with no problem. Upgrading the trans will require you to go with a C6 trans. This requires a little modification to the mounting points and drive line, but still very doable.
Hope that helps some, keep asking questions. --Mike
Help! Thanks!
I'd keep the original engine, and rebuild it. A rod knock usually means one bearing has gone bad. Many of the rebuilt engines sold today are crap.
You can convert your present 352 to a 390 by boring it out, and using a 390 crank and rods.
Remanufactured cranks are available from most autoparts stores, and the rods can be bought in your area from Big M Automotive in Williams.
I've bought parts from Mike, he owns a wrecking yard and builds destruction derby cars.
Keeping your present engine will save you money from swapping, then rebuilding some other engine.
Buying a used engine is a like buying a pig in a poke - you don't know what its condition is.
The ONLY shop I'd recommend to do the work is Bill's Auto Repair in the city of Orange (714-639-3410).
While it's 450 miles south of Chico, the owner specializes in pre-computer Fords, and has down work for me.
He's a grumpy old cuss, but a master mechanic, and does a lot of work on Fords owned by SoCal Galaxie Club members.
He also does all sorts of conversions.
What motor do you have now? Would seem reasonable to either rebuild or replace with the same. Of course, that decision would also depend on what you plan on doing with the truck. (daily driver, work truck, show truck, hot rod, restoration,etc) I would suggest, if you haven't already, post the vin # and have the fellows decode it for you. Then you'll know what should have been there. LOL, I will bet you'll get as many different opinions as to the "best motor" as you do replies.
If you use the search engine you'll find all the answers you'll need to learn how to do the upgrades for the brakes & power steering. You'll also find information on which trannys will bolt to which motors.
Don't forget to post before & after pictures to your gallery so we can all watch as you make your truck your own.
Judi
Try here to look at the different engines. Figure 44 is the FE family of engines. You'll notice that he heads are shaped differently like MikeG posted. </title></head>"); newWindow.document.writeln("<body><div align='center'><img " + getWidth("yes") + "src='/images/cds/" + tpe + "/" + sze + "/" + pc + "." + tpe + "'></img></div>"); newWindow.document.writeln("<div align='center'><table><tr><td><FORM
On another note--I want you to know that although I haven't posted anything since I first joined up (last summer!) I frequently visit and read what's going on--it's nice to see what a great community has been developed via this site. Very Cool!!
Jen
That'll be the day. These truck have the aerodynamics of a brick!If someone swaps to a 302, the city mileage will drop, because a 302 has much less torque than a 352, so you'll have to stick your foot in it to get it going.
With a 300 I-6 or a 352, the truck will get the same city MPG with either engine.
Swapping to either a 300 I-6 or a 302 will increase your highway MPG, mebbe one or two gallons at best.
Is that paltry MPG increase worth the time and expense of swapping engines?
I think not.
Since I've owned the same 1965 F100 Styleside (original 352 2V built to a 390 4V in the early 1980's) with stick & overdrive since buying it new in March 1965, I'm not just whistling Dixie.
Average city MPG on a good day = 10-12.
Highway MPG with overdrive = over 20 MPG is obtainable if you drive 65 MPH or less.
At 65 MPH without overdrive, the truck burns 30% more gasoline than it does at 55 MPH.
Just my opinion, welcome to FTE, please keep us updated, I look forward to following your progress. I am in the same boat with a Bronco of mine right now, it's gonna get a 408w stroker motor, but that's another thread in a different forum!P.S. pics, pics, pics!!!
