4R70w Question!
Old Apr 11, 2008 | 06:01 PM
Hendricksbus's Avatar
Hendricksbus
4R70w Question!
when holding a stead speed the Vehicle will through it's self in what seems neutral, the engine revs like its in neutral until the it hits 35 or 30mph! the trans will re-engage u can acc. back up 55mph! does it frequently! then does spreratically on a drive!
thanks for any advice!!
Old Apr 13, 2008 | 08:47 PM
Hendricksbus
Changed fluid and filter! still does it!! Would the sensor on the side of the tranny where the shift cable hooks up?, cause this sudden slip of the trans.!!
Old Apr 14, 2008 | 07:20 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Yes, it's possible. It's called the Transmission Range Sensor, or TRS.
Old Apr 14, 2008 | 04:57 PM
12secondstang's Avatar
12secondstang
How about this part it was in my pan when I pulled it for a filter change.
Old Apr 14, 2008 | 08:53 PM
Mark Kovalsky
That part was part of a nationwide contest. One transmission had that part in the pan. If it was sent in to Ford by April 1, 2008, it was worth $1 million. You should have changed the oil sooner!
Either that or it's the shipping plug for the dipstick hole in the trans. When the dipstick is installed at the truck assembly plant the plug is pushed into the pan. It sits there until the first time the pan is pulled, then it shows up in a forum somewhere.
chad_mcvay
2004 - 2008 F150
Nov 21, 2012 06:04 AM
grizzly6.0
6.7L Power Stroke Diesel
Jan 17, 2012 03:15 PM
eriddell
Jun 25, 2011 08:24 AM
Duct Tape Racing
Nov 30, 2010 10:58 AM
baileybones
Feb 22, 2007 07:31 AM
