Slipping into neutral 05 Expedition
Old May 23, 2011 | 08:24 PM
eriddell's Avatar
eriddell
Have an 05 Expedition, it is slipping into neutral when in overdrive. If I stay under 20mph it will stay in od. Anyone help me?
Thanks
Ed
Old May 23, 2011 | 08:52 PM
alloro's Avatar
alloro
1. Have you checked the fluid level?
2. When was the filter and fluid last changed?
Old May 23, 2011 | 08:54 PM
eriddell's Avatar
eriddell
Was a little low on fluid, added some and didn't make a difference. Hoping it is a sensor.
Thanks
Old May 23, 2011 | 08:58 PM
ford390gashog's Avatar
ford390gashog
OD clutch pack sounds like its spent! Has the tranny been hunting for gears?? Thats when it shifts out of OD and back into real quick like when in heavy traffic or towing.Also the OD should not stay engaged at 20mph thats an issue by itself. The programing will have it in 4th coming into third by then. If you turn the od off and drive it does it slip in any other gear???
Old May 23, 2011 | 09:04 PM
eriddell's Avatar
eriddell
No issues before today and when the od is off it stays in gear
thanks
Old Jun 25, 2011 | 07:52 AM
Scott Andrew's Avatar
Scott Andrew
I'm having this exact same issue... Any update?
Old Jun 25, 2011 | 08:23 AM
eriddell's Avatar
eriddell
Yeah had to get the tranny rebuilt, to the tune of $2200! Don't take it to a dealership if you have a small garage that you trust they will do it for half the price. The rebuild kit is less than $400.
Old Jun 25, 2011 | 08:24 AM
Scott Andrew
Ok, thanks
wakechica21
1978 - 1996 Big Bronco
Aug 22, 2014 01:13 PM
MR JDuece
Apr 29, 2013 08:06 PM
bvmbandit
May 13, 2009 02:38 PM
RVBfordman
Jul 18, 2006 08:49 AM
