Offroad & 4x4
Replacing Rivits
Old Apr 10, 2008 | 09:50 PM
78f250_rls's Avatar
78f250_rls
Replacing Rivits
I was reading on another thread about you show replace the rivets if you stripped down to the frame, well I am down to the frame.
This has always been a desert truck and has no rust (except where my Survey crew spilled their coffee every day on the passenger side floor board). Also this truck will not be abused 4x4ing, just what 4x4ing that needs to be done for my camping and hunting.
Should I replace the rivets? and if so, is that all of them or just the ones that hold the hangers?
Old Apr 10, 2008 | 09:57 PM
Ryan50hrl's Avatar
Ryan50hrl
If thats all you're doing with it you'll be fine....its just at very abusive wheeling speeds/angles/stunts that they should be replaced
Old Apr 10, 2008 | 10:01 PM
78f250_rls's Avatar
78f250_rls
That sounds good, I was looking and all I could see on the frame was rivets, lol. Figured that would be this weekends job, but the all looked tight still.
Thanks
Old Apr 10, 2008 | 10:02 PM
Ryan50hrl's Avatar
Ryan50hrl
that wouldn't be a bad thing to do....go get a hammer and tap each one...make sure they're all tight....replace any that aren't
Old Apr 10, 2008 | 11:58 PM
captain p4's Avatar
captain p4
Seems like a lot of work for something that most likely won't matter, I wouldn't worry about it.
or do what Ryan said
Old Apr 11, 2008 | 05:47 AM
bucks77ford's Avatar
bucks77ford
I knocked out all mine and replaced with some grade 8 bolts. I can't remember the sizes off hand, but the rivet holes are smaller or larger than a standard bolt size, so I just drilled out the holes to the exact size of the bolt so there wouldn't be no movement of the crossmembers. Turned out nice, but what a pain to do. It was nice because I was able to get everything sandblasted and painted, but would I do it again.........I don't know.
Old Apr 11, 2008 | 06:38 AM
teds74ford's Avatar
teds74ford
For what you are doing, I wouldn't think it would matter. I use my truck similarly, and have had no problems. I would suggest, however, removing the suspension rivets. This way, you can modify it later without the pain of removing the rivets with the body on. I tried this for my rear suspension, and ended up pulling the bed off so I could really let the sledge work its magic. Just use grade 8 and the all metal nuts
Old Apr 11, 2008 | 11:54 AM
Ford150/428/dud's Avatar
Ford150/428/dud
If I recall they were 7/16 I had to run a bit throught a few of them so the bolts would fit in.
Old Apr 11, 2008 | 12:34 PM
rebocardo's Avatar
rebocardo
I would remove all the suspension rivets and leave the body mount rivets.
Old Apr 12, 2008 | 07:02 PM
crazyredneckanyhow's Avatar
crazyredneckanyhow
All of my suspension rivits have been replaced wiht 1/2" grade 8 bolts. Not gonna break anything there. I did take all the body mounts off to make sure there was no hidden rust. I replaced them with 7/16" grade 8s. I know prolly a lil overkill for cab mounts but hey i liek to be safe.
Old Apr 14, 2008 | 10:32 PM
78250crewcab4x4's Avatar
78250crewcab4x4
I replaced all mine with either 1/2 or 7/16 grade 8 bolts, if there isn't much rust I'd leave it alone, it's a lot of work
CAMiniTruck
22
Feb 7, 2014 10:44 PM
Franklin2
1983 - 2012 Ranger & B-Series
Jan 28, 2012 07:46 PM
ErrorS
1978 - 1996 Big Bronco
Aug 29, 2011 11:53 AM
NMf250
Jan 8, 2006 12:27 PM
captntim
Oct 24, 2001 04:45 PM
