Anyone know what a compression test should show on a 97 f250 with the 7.3 I have found one with 300 k miles but he said it has good compression test and Im not that worrie bc its only $6000 dollars and the truck is in good condition any thoughts
Yep what Joe said. Got my gauge set yesterday and will be testing my parts truck motor before I rip it out tomorrow. Then gonna test my truck when I get a chance. Hoping both will be what Joe said but I don't think my truck will look real good.
Any compression test tool for diesels is probabaly ok, long as the guage goes up to 4-500psi. PSD's need a glow plug adapter. I couldn't find one locally and was in a hurry when I needed it, so I looked at pictures online and then made my own. I bought a brand new grease gun hose for $5-6. Then I cut the tip off and pulled the core out of an old glow plug. I welded the new hose onto the glow plug body and ran my test, piece of cake.
Tim, the PSD glow plug adapter has a flexible hose permanently attached to it, the 90 degree fitting you are worried about connects to the end of the flex hose way above the heads so it's not in the way.
