Compression Test
Old Apr 9, 2008 | 02:28 PM
BENG0924's Avatar
BENG0924
Compression Test
Anyone know what a compression test should show on a 97 f250 with the 7.3 I have found one with 300 k miles but he said it has good compression test and Im not that worrie bc its only $6000 dollars and the truck is in good condition any thoughts
Old Apr 9, 2008 | 05:49 PM
ryaneverk2's Avatar
ryaneverk2
Moved to the 7.3L PSD section.
Old Apr 9, 2008 | 06:45 PM
c00nhunterjoe's Avatar
c00nhunterjoe
as long as they are within 10% of each other you should be ok, in general most 7.3's hover around 375-400 psi or better
Old Apr 9, 2008 | 09:13 PM
tjbeggs's Avatar
tjbeggs
Yep what Joe said. Got my gauge set yesterday and will be testing my parts truck motor before I rip it out tomorrow. Then gonna test my truck when I get a chance. Hoping both will be what Joe said but I don't think my truck will look real good.
Old Apr 9, 2008 | 11:50 PM
RubberDuck's Avatar
RubberDuck
Tim, where did you get your setup to test compression on our trucks? I need some new tools. LOL
Old Apr 10, 2008 | 12:10 AM
kawa's Avatar
kawa
RD:
Go to E-Bay and type in: Diesel Compression Tester
You will be swimming in them and reasonable as all hell.
Rog
Old Apr 10, 2008 | 05:37 AM
tjbeggs's Avatar
tjbeggs
This is the set I bought
eBay Motors: MityVac Digital Diesel Engine Compression Tester Kit (item 360012504476 end time May-08-08 13:42:52 PDT)
The reason I went with this set and not one of the others is that it specifically states it works on the PSD and its brand name. The others are no name and just say they are for 6.9/7.3's so I don't know for sure they have the right adapter for the PSD.
Old Apr 10, 2008 | 10:05 AM
MagKarl's Avatar
MagKarl
Any compression test tool for diesels is probabaly ok, long as the guage goes up to 4-500psi. PSD's need a glow plug adapter. I couldn't find one locally and was in a hurry when I needed it, so I looked at pictures online and then made my own. I bought a brand new grease gun hose for $5-6. Then I cut the tip off and pulled the core out of an old glow plug. I welded the new hose onto the glow plug body and ran my test, piece of cake.
Old Apr 10, 2008 | 11:25 AM
Cuda_jim's Avatar
Cuda_jim
Good ole American ingenuity at it's finest
I'm gonna make one, reps sent.
Old Apr 11, 2008 | 05:41 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
This kit is what I got:
http://www.harborfreightusa.com/usa/...ic%20Equipment
Old Apr 11, 2008 | 05:53 PM
tjbeggs's Avatar
tjbeggs
Originally Posted by RÖENTGEEP
Have you used it yet? if so how do you get the hose down to the adapter. With that 90 fitting it looks like it would be a bit hard to get in there.
I use my set yesterday. It worked well but the short (compared to the GP) stub below the threads made it tricky to get starting in the threads.
Old Apr 11, 2008 | 06:49 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
No I havent yet, and I dont know when sorry TJ, but IIRC some one in this forum recomended the kit (Cuda?)
Old Apr 12, 2008 | 09:24 AM
MagKarl's Avatar
MagKarl
Tim, the PSD glow plug adapter has a flexible hose permanently attached to it, the 90 degree fitting you are worried about connects to the end of the flex hose way above the heads so it's not in the way.
Old Apr 12, 2008 | 09:29 AM
tjbeggs's Avatar
tjbeggs
Mine has that setup but I didn't see any flexible hose in the kit that Jose posted.
Old Apr 12, 2008 | 07:39 PM
c00nhunterjoe
tj, what were your readings? didnt you thin kyou had a dead cylinder?
