Modular V10 (6.8l)
ACCEL coils for the v10
Old Apr 8, 2008 | 03:14 PM
shore's Avatar
shore
Im thinking about buying a set of ACCEL coils for my v10. Is anyone using these coils? If so how do you like them.
Old Apr 8, 2008 | 04:25 PM
armynavyguy's Avatar
armynavyguy
Hopefully they aren't as expensive as the COPs at the Ford dealership. They wanted $82 a piece.
Old Apr 8, 2008 | 04:36 PM
shore's Avatar
shore
The last time i checked the were around 25.00 a piece through Jegs and Summit Racing.
Old Apr 8, 2008 | 05:24 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
If you do it, please report back.
I remember only one person having ever tried them, and they failed at a very high rate.
Old Apr 8, 2008 | 06:10 PM
BLK94F150's Avatar
BLK94F150
Look on Ebay for the Global Automotive COPs. They are less them $100 for 8 (I know not 10 but maybe they have a 10 pack) shipped. I have heard great things about them on other F150 only forums.
I'm going to be changing all my almost 100K orginals with these and see if it cures my TC lockup shudder with the 5.4 and 4R70W in the F150.
Mike
PS-V10s rule.
Old Apr 8, 2008 | 06:33 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I put a set of Accels on my V10 a little while ago. They have less than 1000 miles, but so far so good.
Old Apr 9, 2008 | 09:30 AM
krewat's Avatar
krewat
Originally Posted by BLK94F150
I...see if it cures my TC lockup shudder with the 5.4 and 4R70W in the F150.
Did you do the Mercon V flush yet?
Old Apr 9, 2008 | 08:22 PM
BLK94F150's Avatar
BLK94F150
Yeah, that was the first thing I did.
Mike
Old Apr 11, 2008 | 09:13 PM
Fastbird's Avatar
Fastbird
I didnt have luck with accel coils.I already have to replace two of them,one after 400 mils and other one last 600 mils.
Old Jul 13, 2008 | 09:40 AM
Mark Kovalsky
They lasted 1500 miles. Then two failed. Two cylinders were completely dead. The two bad ones were replaced by warranty (I had to install them.) That cured the two dead cylinders, but I still had an intermittent miss, plus one cylinder would shut off at WOT just before the 1-2 shift.
I replaced all 10 Accels with coils from Standard Parts. Now it runs on all 10 all the time.
The two brands have a design difference that I think may explain the problem with the Accels. The spark plug contact is right at the end of the booton the Standard parts. It's about a half inch up in the boot on the Accels. If the contact isn't real good the plug may not get fired.
The Accels are in a box to go back to where I bought them tomorrow. Maybe I can salvage a bit of money from those 10 pieces of junk.
Old Jul 13, 2008 | 10:56 AM
Tony G's Avatar
Tony G
How do you determine which coil packs are bad.??
Old Jul 13, 2008 | 11:34 AM
BLK94F150's Avatar
BLK94F150
You can move them around and see if the misfire codes follow the suspected coils.
My Ebay coils are still going strong in my 5.4.
Mike
Old Jul 13, 2008 | 08:37 PM
Mark Kovalsky
My truck is an over 8500 GVW and those didn't have a very good misfire detection. When the coils first failed it did set a misfire code for cylinders 7 and 8. I moved those coils to 5 and 10, because those are the easiest to change on a van. I drove almost 300 miles trying to get it to set a code again. Never happened. I pulled spark plugs and changed the two with the wet plugs.
Old Jul 14, 2008 | 08:57 AM
surfpozer's Avatar
surfpozer
I bought the Global Automotive COPs from ebay (all 10) cheaply.. have ran tham approx 2000 miles and one went bad. I replaced with one of the old stock COPs. My SES came on for the first time and actually told me which COP was bad. No problems since...
Old Jul 15, 2008 | 02:20 PM
Mark Kovalsky
Sigh. It wasn't the Accel coils. At lunch time today one cylinder decided it didn't want to play anymore. It's back to being a V9.
Bills68F250
19
Sep 28, 2016 10:36 AM
Mark VII
Feb 25, 2016 09:44 PM
AppocAlexx
Modular V8 (4.6L, 5.4L)
Jan 24, 2012 11:18 PM
oldblue89
36
Nov 25, 2010 05:23 PM
Tony G
Modular V10 (6.8l)
Apr 28, 2008 10:12 AM
