I am just bored cause the wife is watching some dumb TV shows.
HAHAH!!! My girlfriend sits there and watches those dumb shows, so i take the iPod touch i just got her and cruse some FTE while sitting on the couch! Good Stuff!
Did you check the VSS first? It's the sensor on the top of your rear axle. Check/clean connections and remove the sensor and clean it. It's normal to find some metal shavings on it. you could get a new one, there pretty cheap at a parts store, just be sure you ask for a RABS (rear anti-lock brake sensor) because if you ask for VSS the'll give you the wrong part chances are
