Speedometer Problem Question
Hey Guys!
The question is...my speedo a couple days ago all of a sudden started bouncing back and forth about 10mph's at a time. it goes down from the actual speed. and if this helps i cant use the cruise control it kicks out when it bounces down. thank you |
Check the connector for the speed sensor on top of the rear axle. Could be loose or corroded also could be a bad sensor.
omg tim you got an answer for everything... i forgot how many topics you answer hahahha
Originally Posted by glasseater
(Post 6009194)
Originally Posted by tjbeggs
(Post 6009206)
you know that additive personality!! I just can't get enough of PSD's!
(Post 6009222)
i'd be afraid to see what you'd do with an unlimited amount of mods for a 7.3 :-bigparty
(Post 6009242)
I would have at least 4 trucks! modded to the hilt! all built for different purposes, Daily driver, 1/4 mile, truck pulls and dune runner!
(Post 6009194)
AND yes... It's probably VSS or connection leading to it. If you getting one from autozone or similar place, it's called a RABS (Rear anti-lock brake sensor) they'll give you the wrong part if you ask for VSS -Robb |
(Post 6009252)
no dyno queen? hahaha you'd put the psd above any cummins or dmax lol
(Post 6009341)
If I could have anything I would have the 4 above and 1 each of a Cummin's in a Ford though (no Dodges here!) and a chevy D-max.
I smell a PSOM issue...
Originally Posted by superduty4x4
(Post 6009476)
PSOM- programmable speedometer odometer module
PSOM = (Programmable Speedometer Odometer Module)
EDIT: DARN Tim you're too fast!!! |
Originally Posted by Robbgt
(Post 6009543)
