DIY Coolant Filter?
Old May 9, 2008 | 03:00 PM
jmaskew's Avatar
jmaskew
Originally Posted by diesel_dan
Well, I finally got together all the parts to do my coolant filter, other than fab'ing the bracket and buying the hose.
So I don't know why I didn't check this before, but I called my local dealer (largest in my area) and spoke with the service manager. I asked him if installing a coolant bypass filter would affect my warranty. He said: absolutely! He went on to say Ford is cracking down on the dealers for just about any warranty work on a 6.0, and he'd have to deny warranty on any related part (pretty much anything related to cooling by the coolant), or face trouble with Ford if they audit a job and catch the filter on there. He said they routinely check on the expensive jobs like head gaskets, etc., now...
I explained to him how the filter works and is benign to the cooling system, and he just said: "wouldn't matter, it's a modification -- if it was a 7.3 it would be different...!"
I guess I have to wait another 3 years to install it...
That is a bummer! They can't understand that a $150 legitimate modification WILL prevent failures that will cost them thousands of dollars. It must be a control issue... they didn't come up with the idea first for the Superduty's!
Old May 9, 2008 | 04:05 PM
slowmans's Avatar
slowmans
sounds like a bunch of crap to me!
Old May 9, 2008 | 04:22 PM
diesel_dan's Avatar
diesel_dan
Yeah, I went on the Ford website and asked the question of them. I mentioned the fact that Navistar puts them on their applications of the 6.0, plus numerous other diesels have them as a preventative maintenance item. I also mentioned my primary reason was to keep the egr cooler and/or the oil cooler from clogiing with coolant sediment or casting sand... We'll see what they say...
Old May 9, 2008 | 04:25 PM
OZX1's Avatar
OZX1
...I called my local dealer (largest in my area) and spoke with the service manager.
...I explained to him how the filter works and is benign to the cooling system, and he just said: "wouldn't matter, it's a modification -- if it was a 7.3 it would be different...!"
Dan, PM sent
Old May 9, 2008 | 04:41 PM
origcharger's Avatar
origcharger
Yeah, I went on the Ford website and asked the question of them. I mentioned the fact that Navistar puts them on their applications of the 6.0, plus numerous other diesels have them as a preventative maintenance item. ...
Actually Navistar quit putting coolant filters on any engine about 2001 when they went to ELC. They never put them on VT365s.
Also International blames many EGR cooler failures on low or improperly filled cooling systems containing air pockets.
Old May 9, 2008 | 05:21 PM
diesel_dan's Avatar
diesel_dan
dang! And here I thot I was making a good case for them...
Old May 9, 2008 | 05:55 PM
Kep4's Avatar
Kep4
Jäger
How ironic... since Ford mandates we keep the 6.0 coolant at the 'Min' level to avoid puking coolant!
Where did you get that information on International and the cooling system levels?
BTW Dan, when I've taken my truck in the Techs (Galpin and Tuttle-Click) didn't know or ask what the coolant filter was for. When I told them what it was they thought it was a great idea. Go figure...
Old May 9, 2008 | 06:19 PM
diesel_dan's Avatar
diesel_dan
Well it IS a great idea! Hell, Ford should have one on there from the factory, from all the posts we've read about the crud that gets filtered out of the cooling system...
Old May 9, 2008 | 08:37 PM
Kep4's Avatar
Kep4
Jäger
My experience at Ford Service with my truck, an '05 Freestyle (turned in from lease! ) and my '94 Bronco (still miss it...) are that the Service Advisors and Managers are not the people to discuss these things with, you really should go directly to the Certified Technicians. The guys getting greasy and turning the wrenches are far more likely to understand and work with you than the desk jockeys.
Old May 9, 2008 | 10:33 PM
origcharger
Fords "MIN" level may not be low however.
International promotes using a special cooling system filling tool that assures complete cooling system filling without air pockets, the use of which lessens the chance of EGR cooler failure. International spokesman at a meeting this past week told us for best success with the VT365 to tolerate no coolant leaks which helps avoid EGR cooler killing air pockets and to stay on top of the oil changes. They also said one of the achilles heals of the VT365 is the cooling system is "plumbed" in series, a problem in one component effects flow to the others.
I can see where coolant filters can be a benefit as long as the installation does not contribute to an air pocket problem.
International quit using them becuase of the Extended Life Coolant, they did not want to chance having the precharged with additive coolant filters designed for conventional coolant mistakenly used and causing problems.
Old May 9, 2008 | 10:38 PM
Kep4's Avatar
Kep4
Jäger
Thanks for the info origcharger. Tossed some rep your way.
Old May 10, 2008 | 06:52 AM
bismic's Avatar
bismic
The coolant filter is still a great idea. My recomendation would be to install it and then you can either take it off when going in for service OR, once your coolant filters come back clean, you probably can take it off for good. Based on my experience, this is going to take at least 30,000 miles though!
Old May 10, 2008 | 07:40 AM
  #28
origcharger
"The coolant filter is still a great idea."
I would tend to agree. If the VT365/6.0 cooling system is plumbed in series and restrictions in flow in one component directly effect the service life of the others, then less crud floating around in the system should be a good thing.
The warranty issue may come into play becuase its a modification and there are no Ford guidelines for components, location, mounting and plumbing of the filter.
Old May 10, 2008 | 10:22 AM
  #29
bismic's Avatar
bismic
For the DIY folks - get some hose AND valves rated for the temps. The hoses in my kit stuck TIGHT to the barbed connections and hardened. I am putting a VERY LIGHT film of high temp plumbing grease on the barbed connectors before I tighten them down. I do not want to have to CUT the hoses off again. So far, absolutely no leaks w/ this!
Old May 10, 2008 | 01:05 PM
  #30
OregonF350's Avatar
OregonF350
I'd find a differant dealer, I just had headgaskets done and they didn't question the bypass filters for coolant or oil on my truck. The only thing they wanted to know about was if it had a chip or tunes.
