hop up's
Old Apr 6, 2008 | 04:32 PM
stevilknevil's Avatar
stevilknevil
hop up's
i was just wondering what i could expect from a turbo kit?is there really that much to gain without giving up reliability and simplicity.i really don't haul huge loads i have a K.W. for that.but you can't overlook the cool factor.
Old Apr 6, 2008 | 05:16 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Remove the boot after the turbo on your KW and check out the difference.
A turbo is the biggest single performance upgrade you can do to a NA diesel.
At modest boost levels, it may actually make the engine last longer, you don't have to run it as hard.
Old Apr 7, 2008 | 10:50 PM
Marianna2003's Avatar
Marianna2003
Does anyone know what the maximum power you can pull out of the 7.3IDI engine without totally sacrificing reliability?
Old Apr 7, 2008 | 11:27 PM
Dave Sponaugle
Over 300 HP is not out of the question, and still have a reliable engine.
Old Apr 8, 2008 | 01:49 PM
stevilknevil
these older motors must be tougher than i thought.
Old Apr 8, 2008 | 02:41 PM
David85's Avatar
David85
They are much stronger than they had to be for the stock configuration, but I have yet to see an example of a failure that cannot be linked to poor maintenance (even when hopped up). Just look at the main bearing caps in this:
Old Apr 8, 2008 | 03:06 PM
mistakenID's Avatar
mistakenID
(was just wondering what i could expect from a turbo kit?)
On my 85 the difference was: First year I had it, loaded 9.5 ft camper, 22 ft boat with tandem axle trailer. Enough food and camping/playing crap for a week. Started up the canyon and could only do 22 mph. Loaded semi's were passing and the drivers were talking about the "#$%@ tourists jamming up the road. That cut deep as I was an owner-operator at the time.
I told the wife, This just ain't gonna cut it. That winter I put on the ATS turbo kit and exhaust, got the pump rebuilt and calibrated, changed the cam timing.
The next year, same camper, same boat, loaded pretty much the same and the same canyon.........63 mph. I sold the truck in 94, last time I saw it was a couple years ago and the guy said he not had any trouble with the engine. It had over 150,000 miles on it at that time.
Old Apr 8, 2008 | 03:25 PM
David85's Avatar
David85
Wait a minute here, you changed the cam timing? Please tell more, what difference did it make? I never heard of any custom cam work ever being done on the IDIs.
Old Apr 8, 2008 | 07:20 PM
stevilknevil
so,all the time i have had the truck that the 7.3 i am putting in my '79 i could have had a turbo and not hurt the motor.figures.seems as though i need to study up on the IH motors.
Old Apr 9, 2008 | 06:35 AM
mistakenID's Avatar
mistakenID
David85, it did not make enough difference to make me want to do it again. It has been so many years ago that I don't even remember how many degree's we cut the key way.
It did run smooth and had no trouble with heat. On the old cummins engines, we used to change cam timing whenever we jacked up the fuel pump to a hot setting. I figured the 6.9 would benefit also. We setup my dads truck about the same way but without the cam timing change and it didn't seem to make much difference.
The differences in pulling a load seemed to be more related to gearing. He has an 87 with 5sp and I had an 85 with 4sp. Axle ratio's were the same.
Truck815
20
Feb 9, 2016 07:03 AM
Olweldinrig
Mar 7, 2014 11:37 AM
BlueovalFE
17
Jan 3, 2013 01:17 PM
Restoman2
Mar 18, 2011 12:40 PM
Carnivore
2004 - 2008 F150
44
Dec 26, 2004 09:03 AM
