140v idm mod
Old Apr 8, 2008 | 08:43 PM
  #46
FARM69's Avatar
FARM69
I need to do this..... So does the link as to where to get the hardware work still?
Old Apr 9, 2008 | 07:41 PM
  #47
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Yes. The links in post #2 and post #21 are working fine.
Old Apr 10, 2008 | 10:30 PM
  #48
jimwilsonmasonry's Avatar
jimwilsonmasonry
i got my resistors in the mail today but im not gonna do the mod till tomorrow
Old Apr 11, 2008 | 12:01 PM
  #49
kawa's Avatar
kawa
I did the IDM mod yesterday and everything went as planed. But I'll give you a tip: It helps immensely if you have the eye of an Eagle, the fingers of a Raccoon and the intestinal fortitude of a base jumper.
After it's over, It's back in place and the truck starts and runs great, then and only then is it a Piece of cake
(Ya didn't screw it up)
Rog
Old Apr 11, 2008 | 12:03 PM
  #50
jimwilsonmasonry
how did you get the little resistor out of the idm
Old Apr 11, 2008 | 12:12 PM
  #51
tjbeggs's Avatar
tjbeggs
Rog
What happens if you have the sight of a bat, fingers of an elephant and intestinal fortitude of an anorexic?
I think I am in trouble!!!
Old Apr 11, 2008 | 12:35 PM
  #52
jimwilsonmasonry
just waitin for the silicone 2 dry
Old Apr 11, 2008 | 12:40 PM
  #53
kawa's Avatar
kawa
TJ, you will only be in trouble if your little elephant fingers get cold
Rog
Old Apr 11, 2008 | 12:42 PM
  #54
kawa's Avatar
kawa
BFH & little screw driver
Old Apr 11, 2008 | 12:44 PM
  #55
tjbeggs's Avatar
tjbeggs
Rog
LOL well its getting warmer out but this should be an inside job now matter what. I think I will be ok as long as i turn up the heat to 75! LOL
Old Apr 11, 2008 | 12:45 PM
  #56
tjbeggs's Avatar
tjbeggs
Ouch! sounds like a new IDM to me!
Old Apr 11, 2008 | 01:34 PM
  #57
Neal 97 250's Avatar
Neal 97 250
That is when you call Beans.
Old Apr 11, 2008 | 02:34 PM
  #58
secondarychaos's Avatar
secondarychaos
Wipe him off the face of the FTE Scott!!
Ouch TJ, what did i ever do to you?
Scott- your story of IDM's reminds me of the time that i admitted to a friend of mine that i have experience changing clutches. His truck was over my pit As soon as i offered to help... lol
Rog- How long did this take you?
Old Apr 11, 2008 | 03:14 PM
  #59
tjbeggs's Avatar
tjbeggs
All in good fun! LOL
Old Apr 11, 2008 | 03:20 PM
  #60
kawa's Avatar
kawa
Removing the old resister just a couple of minutes, I used a very small screwdriver, placed it in the middle at the edge of the resister and taped the screwdriver. The resister broke in half and I picked the two (2) pieces out.
Took the new resister and bent the ends into two (2) tiny little feet pointing at each other. I used all of the resister just as it came except for the feet. (Madvan gets credit for the feet & using all of the resister)
I then tinned the feet, placed the foot on the farthest point where the original was, put a drop of solder on the iron and touch it to the foot and the solder flowed. (1 second) Then did the same with the second foot.
This resister is now quite tall so I used a small portion of the RTV glue and glued it to that blue "Stack" (Don't know what it is) so that vibration from the vehicle wouldn't cause the new solder/resister connection to break.
The whole removal and replacement took about 15 minuets. The toughest part was De-gluing the cover and the case. The cover, I got it off without and damage whatsoever. I started to use a razor knife and figured my life expectancy was working against me so I took it over to the grinder with a medium wire wheel and had the cover cleaned in five (5) minuets.
To clean the case I used a razor knife and cut along both sides of the "Groove" then used the same small screwdriver to scrape it out.
After I was through the lid would just fall into place, turn it over it would fall out. It was clean.
I used the Grey RTV and ran a generous bead all around the case, laid the lid in place and put a small anvil, (3-4lbs) on the lid and let set for an hour or so to let the RTV set up. While waiting I took a small brush and lightly coated the connection pins with dielectric grease.
It started and it ran super.
Rog
