Cold AC
Old May 16, 2008 | 09:45 PM
  #31
camodown's Avatar
camodown
Try tapping into the white line. It works better imo.
Old May 16, 2008 | 09:47 PM
  #32
BanksPSD's Avatar
BanksPSD
Originally Posted by sflem849
Are you sure the valves are opening/closing when they should?
No felt difference or no difference with a thermometer?
I used a thermostat and I saw no difference. I'm not sure if the vave is working the right way but I followed the instructions on this forum:
https://www.ford-trucks.com/forums/5...ditioning.html
Old May 16, 2008 | 09:51 PM
  #33
BanksPSD's Avatar
BanksPSD
Why do you think it wors better? I'd like it to only "work" in the AC/MAX-AC positions... I use the Vent when it is not too hot/cold to run the AC... Right now I think the AC only works when its on MAX-AC, AC, Vent only (no heat what-so-ever)...
Old May 18, 2008 | 12:34 AM
  #34
camodown's Avatar
camodown
Well, I guess I should have worded that better. For me, the white line works better because the white line has vacuum applied on max a/c and off, meaning the heater core wouldn't have any supply of hot coolant in those positions. If you tap into the red line, you are having full vacuum on max a/c, a/c, panel, and panel floor causing cooler air discharge but no heat control over ambient temps. This means you will only get heat in floor, floor defrost, and defrost. Also, in the off position, the heater core will still have coolant circulating.
Old May 18, 2008 | 12:41 AM
  #35
camodown's Avatar
camodown
The A/C compressor is active above 43* F in MAX A/C, A/C, Panel/Floor, Floor/Defrost, and Defrost, assuming you have manual A/C. Of course, EATC uses completely different commands. Max A/C is the most efficient when using A/C because the air is recirculated so less heat dissipation and de misting has to take place causing the compressor to run less. You probably won't need heat much in that part of Tx now that I think of it...
Old May 18, 2008 | 01:15 AM
  #36
1996pwrstrk's Avatar
1996pwrstrk
What temp readings were you getting and what was the ambient temp ?
white Buffalo
Jan 18, 2025 09:58 AM
Blue7.3
Australia Chapter
Dec 25, 2015 11:20 PM
Patriotic Rottweiler
Sep 26, 2014 02:40 PM
Piolet
Mar 9, 2014 06:15 PM
jtharvey
18
Dec 19, 2007 10:09 PM
