Anyone using Dieselsite billet HPOP?
Is anybody using one of the Dieselsite billet HPOP's in their 6.0?
http://www.dieselsite.com/2003-20046...lpumphpop.aspx
Did you buy the 'Slightly bigger than stock' or the 'Adrenaline - high output' version?
Any feedback from anybody appreciated, Thanks.
Thanks David & Tim.
I was thinking that the original did good for me but I'd been reading a few reports of problems too so I figured being that it's deep in there I'd look for an improvement in reliability.
I wanted to make sure the Dieselsite pump would be that upgrade. I found a few posts across the internet where guys posted up about installing them but not much follow up on how they performed or held up etc.
Npccpartsman - will you be going with the stock or high output option? In the future I'm hoping to get FICM tunes, Gearhead tunes, Powermax turbo and new 4" exhaust system .... would the DS stock upgrade be fine or would the adrenaline upgrade be overkill? Just curious.
Did you happen to see this? The newer style is in testing 2004.5 and newer.
http://www.dieselsite.com/2005-20076...reoilpump.aspx
Not that we are seeing the failures like with the blown plugs.
Sean
Sean
Sean
Sean
2003 and all 2004 use the early pump.
Josh
