Removing oil pan
Old Mar 31, 2008 | 05:26 PM
Phils Ford's Avatar
Phils Ford
Removing oil pan
Have 91 Ford F-150 2wd. Trying to remove oil pan to check out lower end of engine and am struggling. I unbolted the exhaust, rmoved all bolts from oil pan, removed bolts on trans bracket and motor mounts. Placed a block under the front harmonic balancer and raised the engine. Heres the problem even with a second jack raising the transmission some I cannot raise the engine enough to get the pan out. I read in a number of posts that removing the intake was not needed yet I can not get the pan out can anyone provide words of wisdom on this issue?
Thanks
Phil
Old Mar 31, 2008 | 06:54 PM
bigbub28's Avatar
bigbub28
removing oil pan
Hi, i have had luck reaching in and unbolting the oil pump first, let it sit in the pan and you should be all set.
Old Mar 31, 2008 | 07:09 PM
Phils Ford's Avatar
Phils Ford
Thanks I will give that a shot I appreciate the help.
Old Apr 1, 2008 | 05:57 AM
alz's Avatar
alz
To replace the gasket, removing the intake is not needed.
To remove the pan, I've had to remove the upper intake on two different motors.
Ol Red 75
Sep 15, 2011 11:23 PM
darkstar8
Sep 11, 2011 07:35 PM
99 F-250
Dec 5, 2009 06:30 PM
92 Red F150
Jan 7, 2008 07:55 PM
jerryh20
May 6, 2007 03:45 PM
