Gear shift indicator light
Old Mar 31, 2008 | 10:44 PM
Mil1ion's Avatar
Mil1ion
From here It looks like he has a pre-77 column
I sent him a PM to send the photo to me directly.
Old Mar 31, 2008 | 10:51 PM
brownfoot's Avatar
brownfoot
yep, he has to poll the steering wheel
Old Apr 1, 2008 | 01:22 AM
Mike's 77's Avatar
Mike's 77
For some reason I can't seem to get any of the picures onto the website. And if I do end up having to pull the wheel I may wait on doing the light until I get a new signal switch and can do it all at once. But I'm still flustered that I can't get any pics to load onto the site
Old Apr 1, 2008 | 09:30 AM
beartracks's Avatar
beartracks
Hey you got my seats! Different material.
Old Apr 1, 2008 | 09:35 AM
beartracks's Avatar
beartracks
Several things changed in mid 77.
Old Apr 1, 2008 | 02:16 PM
Mil1ion's Avatar
Mil1ion
Okay after having a closer look at that steering column you have one like the 75
You have to pull the steering wheel to change the bulb as shown here
Old Apr 1, 2008 | 07:36 PM
Don S.'s Avatar
Don S.
Any special tools needed to pull the Steering wheel?
Old Apr 1, 2008 | 07:37 PM
Mike's 77's Avatar
Mike's 77
Smile
Thanx! That really helps. How hard is it to swap the signal switch? I'm probably gonna do them both at the same time.
Old Apr 1, 2008 | 07:42 PM
Mil1ion's Avatar
Mil1ion
It looks like a snap compared to tilt wheels
Old Apr 1, 2008 | 07:54 PM
brownfoot's Avatar
brownfoot
be careful and keep close track of wire locations on the t/s connector
I think that you will have to remove the wires one at a time from the connector from the old switch and install the new switch wires in the connector
use a very narrow small screwdriver blade to hold the latch of the connector away from the terminal and the terminal will slide out, to put the new ones in just push them in
easy to do , it's just that all have to be removed to remove the switch or you could just cut the old wires a few inches long, remove the old switch and then the locations would be easy to follow one wire at a time
Old Apr 2, 2008 | 08:47 PM
Mike's 77's Avatar
Mike's 77
Talking
Blue turn signals
Here's a close up of my steering column.
PhilZX6
15
Dec 8, 2017 02:55 PM
NCMillwright
2009 - 2014 F150
May 15, 2017 06:38 AM
trophy_fish
Apr 5, 2016 08:05 PM
hoverp
6.7L Power Stroke Diesel
22
Apr 5, 2014 11:36 PM
