Gear shift indicator light
Old Mar 31, 2008 | 02:03 AM
Mike's 77's Avatar
Mike's 77
Recently I've replaced my dash lights in my 77 f150 with blue led's and everything looks great except the gear shift indicator doesn't match. I was wondering what type of bulb it is and how do I get to it??
Old Mar 31, 2008 | 04:01 AM
m78's Avatar
m78
When are you going to post the pictures of the blue dash ?
Old Mar 31, 2008 | 01:04 PM
beartracks's Avatar
beartracks
I believe you have to pull the steering wheel to get at it. I recently did all green LEDs but hadn't thought about that light.
Old Mar 31, 2008 | 01:11 PM
Mil1ion's Avatar
Mil1ion
No you get at it from below the steering wheel collar
Blue/red wire
Bulb #1445
Don't pull on the wire.
Grab the socket with a long pair of needle-nose pliers.
Old Mar 31, 2008 | 01:47 PM
Don S.'s Avatar
Don S.
Blue/red wire
Bulb #1445
I an guessing it is the same process for a 78 f-150 with tilt column? My bulb is burnt out.
Old Mar 31, 2008 | 01:49 PM
Mil1ion's Avatar
Mil1ion
Yep, remove the trim piece from column to dash and reach up.
Old Mar 31, 2008 | 08:55 PM
Mike's 77's Avatar
Mike's 77
Blue/red wire
Bulb #1445
Could you explain more on getting it from below the steering collar? Thanx
And I will post pics as soon as I can figure out how to take a picture in the dark that will show them clearly
Old Mar 31, 2008 | 09:03 PM
Mil1ion's Avatar
Mil1ion
1977 Steering Column Shifter Bulb Removal
Blue/ Red stripe wire is for PRD2L illumination
Follow wire up to bulb socket
Old Mar 31, 2008 | 09:18 PM
Mike's 77's Avatar
Mike's 77
Sure, I'll be back with a photo.
Ok cool thanks
Old Mar 31, 2008 | 09:22 PM
Mil1ion's Avatar
Mil1ion
Photos are up
Old Mar 31, 2008 | 09:50 PM
Mike's 77's Avatar
Mike's 77
<?xml:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shapetype id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" oreferrelative="t" o:spt="75" coordsize="21600,21600"> I just went and looked at my steering column and am still a little puzzled on how to get around that grey part on it. The gear shifter is right there. Any suggestions?</v:shapetype>
<v:shapetype stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" oreferrelative="t" o:spt="75" coordsize="21600,21600"></v:shapetype>
Old Mar 31, 2008 | 09:56 PM
Mil1ion's Avatar
Mil1ion
Can you take a close up of the collar for me ?
Old Mar 31, 2008 | 09:59 PM
Mike's 77's Avatar
Mike's 77
Ya I'll go take one right now
Old Mar 31, 2008 | 10:20 PM
Mike's 77's Avatar
Mike's 77
I took some pics but I can't seem to get them to upload right now
Old Mar 31, 2008 | 10:41 PM
brownfoot's Avatar
brownfoot
you late model guys are lucky, you have to pull the steering wheel on a '76 to change that bulb
