When do you plan to get rid of your true van turbo?
If I had enough $$$ for an upgrade, I'd get rid of it tomorrow. I'm still trying to get things back on track as far as my business goes, after a little setback during the beginning of the year. If all goes well over the next few months, hopefully around July or August I'll be able to upgrade. My van turbo will be up for sale after that, with probably 20K miles on it after the rebuild.
Also, I saw it mentioned the top HP with stock sticks, and I'll agree that it's right around 350 RWHP. With every supporting mod possible (fuel system, intake, exhaust, chip, big oil, turbo, intercooler) and my stock injectors, I was right around 360 HP if you figure it based on my trap speed of 87 MPH and the truck weight of 8000 pounds.
What would you want for it? Assuming I am still looking and you are selling at that time?
I have the adapter from beans....I went to put the van turbo on, but it was from an early 99 so i wasted my time....I put it on the turbo and tried to install it, but it was never ran or completely installed... Will part with it for $80
I honestly hadven't given it any thought. The turbo's pretty fresh, so it wouldn't need a rebuild, but it would kind of depend on whether you wantet the ATS housing too or not. The ATS does have some scarring on the inside from the last turbo failure, but I didn't see performance change because of it. I don't know...PM me with some ideas of what you think.
Yeah, quite a few here have the van turbo. Depending on how much shopping, price checking, and work you do yourself -- you could have anywhere from $300 to $600+ in the upgrade. Me, I watched eBay for a used turbo ($80, which is cheap), rebuilt it myself with a $100 kit, then add the flange adapter from Beans is all that's 100% necessary for you to buy and I'm in it for less than $300. Of course, you can spend more too, by getting a non-EBPV turbo pedistal instead of blocking yours off and add extras like an ATS compressor housing.
orng1, I see you're a pretty new user so some of this may be a little confusing right now, but hang in there and it will make sense. Don't be afraid to ask questions.
Thanks man, I really appreciate it. I've worked on cars for a long time but have never had the opportunity to work on diesels. That is until now that I bought one. I'm just trying to read as much here as I can, and do some research on some things that are coming up on the truck. Right now it's just an injector issue that is setting off the light from time to time.
Aklim, are you planning on more fuel in the future? I see you have the regulated return, just got BO, now the turbo... all preparing for more injector?
Was it that obvious?
I should think that until I do the AC Single shots that make about 70HP, I should be fine without a reprogram on the F5. Those were the injectors that Jody recommended.
