Sponsored by: Real Truck
rearend slipping?
Old Mar 24, 2008 | 09:26 PM
mustangmike's Avatar
mustangmike
rearend slipping?
My problem is kind of hard to explain,but I will give it a shot.On my 01 sd 5.4,when i come to a complete stop, and then take off normal it feels like the rearend has alot of play in it or the u-joints are bad or something.It does'nt make any kind of clunking noise.Could the brakes be hanging up a little?It has done this since about 70,000 miles,now I have 96,000.The driveshaft does'nt seem to have any play in it at all.Anybody else have this problem?
Thanks
Old Mar 24, 2008 | 09:49 PM
99f350sd's Avatar
99f350sd
Have you lubed the splined shaft on the driveshaft? You might want to do that first.
Other than that you might want to jack up the rear and see if you have a limited slip rear diff. Both tires sip the same way...
Dick
Old Mar 25, 2008 | 10:09 AM
johnf350diesel's Avatar
johnf350diesel
i think this is a common problem. i have the same problem and im gonna check my splined drive shaft
Old Mar 25, 2008 | 10:17 AM
ed foster's Avatar
ed foster
My '99 and '04 both have a funny kind of 'shudder' in the driveline when you go from a stop. Everything is tight, I've had the '99 from day one and the '04 is mine for a year. Another thing I notice is sometimes when rolling into the driveway I'll pop it in neutral and coast to a stop and there is a definite 'pop' in the drivetrain. I always chalked it up to the torque 'unwrapping'.
Old Mar 25, 2008 | 12:22 PM
aldridgec's Avatar
aldridgec
Sounds like classic slip shaft problems. If they are two piece shafts on the trucks it is the shaft hanging up as it lenthens and contracts as the pinion rotates when the springs wrap and unwrap.
Alvinmac
Jul 4, 2010 06:31 PM
dasoundman
1978 - 1996 Big Bronco
Jul 11, 2007 09:07 AM
Saigon
Oct 16, 2002 11:19 AM
strawboss
Aug 25, 1999 06:25 PM
