Sponsored by: Real Truck
CB Antenna Mount
Old Jul 8, 2008 | 05:56 PM
packoo's Avatar
packoo
Not the best spot for signal (1.5) but it works for what I need...
best pic I have of location (stainless whip)
Old Jul 8, 2008 | 08:32 PM
f-250 ford's Avatar
f-250 ford
Originally Posted by Bulldog68
I need to ground the bed as well. Where did you get your grounding straps from? Also, what kind of antenna is that? Is that a 10k??
You can go to the local kragen auto parts and ask for some braided ground straps. They are the same ones that ground the engine block to the frame try to get some 3/4in wide or bigger no longer then 12in. If you don't run power you can get away with not gounding the bed but some of the newer cb radios have inturnal amps . Yes it is a 27in shaft Predator 10k
ManfredVonRichtofen
1978 - 1996 Big Bronco
15
Jan 9, 2017 11:30 AM
UPS92008
2015 - 2020 F150
29
Sep 2, 2016 10:02 AM
johnny yahoo
Oct 14, 2013 05:13 PM
strokeorcroak
15
Dec 12, 2010 09:23 PM
ACG
1997 - 2003 F150
Sep 10, 2001 11:39 AM
