engine boots
Old Mar 21, 2008 | 08:07 PM
jays power stroke's Avatar
jays power stroke
engine boots
hello everyone i was wondering where i can get new boots fof the turbo and intercooler. any help would be great thanx
Old Mar 21, 2008 | 08:17 PM
Izzy351's Avatar
Izzy351
Try here:
http://www.dieselsite.com/index.asp?...RODGROUP&ID=14
Old Mar 21, 2008 | 09:26 PM
MTDewX's Avatar
MTDewX
I Just put the same set on today, and they work great.
Great folks to to deal with too.
Old Mar 21, 2008 | 09:36 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Are your factory boots bad? If they are not cracked or split, you can take them off and clean them with a good cleaner. Then put them back on. Most of the time its not the boots that are bad, its the clamps that are not tight enough.
Old Mar 21, 2008 | 09:47 PM
Scottys-350's Avatar
Scottys-350
I can see soot around my boots, is that most likely the clamps
Old Mar 21, 2008 | 10:21 PM
miller_feed
Yes, that is from your ccv, it lets your crank case vent go into your turbo and it comes out of your boots like air with oil mixed in. Take all of them off and clean them, then put them back on. Tighten them up, but not so much that you bend the IC tubes. You can do a search on ccv and you will know what to do to prevent the oily boots.
Izzy351's Avatar
Izzy351
Soot around your boots? You mean oily dirt? That's because the of the stock CCV. Do the CCV mod, clean them up with some Simple Green, and you should be good to go.
Old Mar 21, 2008 | 10:27 PM
Scottys-350
Thanks for the info, I read up on the ccv mod and will be doing it soon. Just ordered a 6637 filter also. Many thanks. Glad this sight is here
Iaff113
Jan 1, 2013 08:12 PM
chris64
Sep 9, 2010 01:36 PM
crazymut
13
Mar 21, 2010 10:20 PM
Munch
1997 - 2003 F150
Jun 8, 2009 04:02 PM
Southernguy101
37
Mar 3, 2005 01:19 AM
