[quote=jeremyled;5972794]to doug.. lastly i dont think i said it was reverse rotation because it is standard rotation. ] You are correct, you never said it was reverse rotation, just that it had a serpentine belt. My mistake. Now I know what's going on. Thanks for the explaination.
AT LAST !!! somone with the same problem as i have !!
Duhh, I mean the waterpump-problem....
I have a 1993 e-150, wirth a strange engine inside. Strange, because i haven't found the number on a 'machined surface' and i have recieved 3 waterpumps that don't fit
I have exactly the same number on the timing chain cover !!
So my question is: Which waterpump did match your timing cover ?
Do you have a number, a supplier, a ford-code, anything that will get me started (and my engine too)
