Transfer Case Shifter
Old Feb 19, 2007 | 05:26 PM
linckeil's Avatar
linckeil
I'm wondering what other models have the same transfer case shifter so that I can find what I need. It is for a 1996 F350 with 5 speed manual transmission and PSD engine. It is a Borg Warner transfer case.
I do not need the shifter cane that comes up through the floor. I need the aluminum piece that the cane attaches to and pivots on the transmission.
I posted an ad in the classifieds, but I need to know what other models will have the same part so that I can search a broader range of vehicles for this part. Is what I need specific to a 5 speed PSD, or will one from an automatic 351 or 460 work? what year range will work? anyone have any ideas? I need to find one ASAP. The dealer wants 5 times what I'm willing to pay, so the used route is the only way for me. If you got one email me at linckeil@hotmail.com
Old Feb 20, 2007 | 04:27 AM
tjc transport's Avatar
tjc transport
i ain't rite
it will be transfer case specific. you will also need to know what type case you have, the B.W.1345 and B.W.1356 use different shifters.
Old Feb 20, 2007 | 08:34 AM
linckeil's Avatar
linckeil
thanks for the reply. i will look for a tag on the trasfer case to identify the model. any suspisions which one i have or there's an equal chance it can be either?
so if i find the same transfer case as mine, it will have the shifter linkage i need regardless of what engine/transmission it's mated to?
Old Feb 20, 2007 | 08:55 AM
tjc transport
i ain't rite
you most likely have a 1356 case, but there is the possibility of the 1345.
and yes, the engine /trans makes no difference. the shifter bolts to the transfer case to trans adapter.
Old Feb 20, 2007 | 11:09 AM
gustang818's Avatar
gustang818
Originally Posted by tjc transport
...and yes, the engine /trans makes no difference. the shifter bolts to the transfer case to trans adapter.
I beg to differ at least as far as a BW1356 is concerned. My E4OD shifter (c)has a long rod (stamped E4OD) while the ZF (r) and M5OD (l) (stamped M5OD) had a short rod. The shifter mount bolt holes are also different. That's how I wound up with this assortment:
Yours looks like the one in the middle?
Old Feb 20, 2007 | 12:56 PM
tjc transport
i ain't rite
oh. OK. i was not aware of that. on all my trucks, the shifter mounted to the t-case adapter, not the trans. and on the 88, when i swapped the 5 speed for the C6, everything stayed the same.
Old Feb 20, 2007 | 02:40 PM
gustang818's Avatar
gustang818
TJC: Maybe the 3 speed C6 is shorter and its 4X4 tailshaft housing is longer? That's good to know that the C6 is the same size as the 5 speed. You didn't have to chage driveshaft length?
linckeil: did you break the aluminum housing? They can be tig welded to good as new.
Old Feb 20, 2007 | 04:09 PM
tjc transport
i ain't rite
the adapter i got from the junkyard was broken, but i replaced it with the same part # from ford. i think it is actually 2 inch shorter than the one that is supposed to be used with the C6, cause the trans mount ended up being 1 inch to short to fit in the cross member. i had to move the cross member forward 2 inch to bolt it all up.. i actually should have lengthened the rear shaft, and shortened the front shaft, but my truck does not leave the ground. if i go off road, i go slow enough to keep all 4 on the solid, and do not bottom out the suspension either. so i don't have to worry about pulling the rear shaft out, and the 2 inches shorter is compensated for in the front slip yolk.
Old Feb 20, 2007 | 04:48 PM
linckeil's Avatar
linckeil
gustang818, yes mine looks just like the shifter in the middle of the picture you posted. the aluminum piece broke. tig welding is an option, but i'd rather replace it with a used one. probably a cheaper option too. you wanna sell me the one in your picture?
Old Feb 20, 2007 | 05:20 PM
gustang818's Avatar
gustang818
I sold it to a guy last November. The guy who welded it up for me had one like it for sale for maybe $30 or so but it also was welded. I think his name was Dave at Marty's Tool and Die Welding in Redford MI 313 531 1255. He did a really nice job welding mine. While it was apart I put a couple zerks in so I could grease it to prevent it from seizing up.
I think that kind of t-case shifter came with the E4OD on at least the 92-96 F-150 and 250s. My '92 F-150 had one and the 94 F-250 I just bought also has the same shifter.
Old Feb 20, 2007 | 06:22 PM
linckeil's Avatar
linckeil
what trans is in my truck? it is a 5 speed manual behind a psd. 1996 F350.
Old Feb 20, 2007 | 06:35 PM
gustang818's Avatar
gustang818
It would be a ZF S5-47. I wound up using the shifter on the left in the foto which came off a 1989 F-150 with a an M5OD 5 speed and it mated right up to my 1996 ZF tranny. The M5OD and the ZF t-case shifters are interchangeable so if you found one of those you should be good. I did have to heat the handle of the 1989 shifter and bend it down because it interfered with the dash.
Old Feb 20, 2007 | 06:40 PM
linckeil's Avatar
linckeil
would the shifter on the left in your photo work for me? it doesn't look like it has to be pushed down when going into low range like the shifter in the center requires.
Old Feb 20, 2007 | 07:21 PM
gustang818's Avatar
gustang818
It should. That's what I put on my ZF trans and it works great. It's one that you pull to the left and then back to get into 4WD. The one on the right came with the ZF when I bought it but it was missing some pieces.
Remember if you get the one on the left that you will probably have to bend the shift handle. Ford changed dashes in the 92 trucks and the shift **** hits. Some heat and black paint and no one will know it didn't grow there.
Old Nov 14, 2007 | 07:10 PM
kpeterson93's Avatar
kpeterson93
were you ever able to find your transfer case shifter, if so where? Or were you able to fix it another way
Thank you
ashleyroachclip
WTB - Parts & other
Aug 17, 2015 05:35 AM
linckeil
Dec 22, 2013 03:33 PM
4tl8ford
May 21, 2013 09:47 PM
erniech
1966 - 1977 Early Broncos
Jun 25, 2006 12:25 AM
airrikk17
1978 - 1996 Big Bronco
Oct 13, 2004 03:48 PM
