DP Tuner probs
Old Mar 21, 2008 | 12:53 PM
fordzilla01's Avatar
fordzilla01
DP Tuner probs
Ok, strange problem... I have a DP tuner, with various setting, but for some reason when I start the truck "COLD" in my 120HP tune, it blows blue. While its blowing blue if I change to another setting like the 140hp or the 80hp etc.. (Basically anything other than the 120hp tune stops blowing blue). But, if I put it back it blows blue again. Kind of a strange one... Don't really know why... Once the truck warms up all is fine in the 120 setting.
Ideas?
Old Mar 21, 2008 | 01:00 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Most people when its cold, starts the truck in stock tune. After it warms up go to any tune you want.
Old Mar 21, 2008 | 01:02 PM
fordzilla01
fair enough, but this problem doesn't make much sense...I never had the problem before... you would think that the 140 tune would do the same no?
Old Mar 21, 2008 | 02:11 PM
miller_feed
This would be a good question for Jody when they are open again, after Easter. I can start mine in any tune and never get smoke like that. I am sure he can help you with this.
Good luck.
Old Mar 21, 2008 | 02:23 PM
ron's power stroke's Avatar
ron's power stroke
As Rick has said..start the truck in stock when cold..the injectors are being pushed too hard with cold thick oil and the motor is not warm enough to burn the oil like its supposed to..
EDIT: i see Diane is in...she will be here soon to explain it better...
Old Mar 21, 2008 | 04:57 PM
fordzilla01
That would be great... this doesn't explain why it only does this in the 120HP tune though...You would think that it would do it in the 140HP tune worse or the same then...
Old Mar 21, 2008 | 05:06 PM
miller_feed
All the tunes are different. Your 120 tune might be putting more fuel or timing to your engine. There may be something about that tune that will make it do that. If you start your truck in stock when cold and after it warms up, and you can switch to your 120 tune and it does not smoke, you should be good.
I don't know for sure about this but I am talking/typing.
Old Mar 21, 2008 | 05:10 PM
ron's power stroke
you got me there..Rick could be right..sounds like a question for Jody...
Old Mar 21, 2008 | 06:33 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Ideas?
One of the main reasons Jody automatically puts stock on the F5 chips now is for this reason. I would start the truck in the 60 tow since that is your lowest setting.
At the time of starting the truck at cold temps the oil is not up to operating temperature. In the higher hp levels the ICP is asked for at a higher PSI then any of the others. Why it is not happening in the 140 is a strange one. Jody would be the person to ask this.
Blue smoke has been defined as oil in the fuel. Why is this happening? Well, it could be the injectors themselves or the o-rings. Run a contribution test first before tearing into the injectors. Doing this test will help you/us diagnose the issue better. Have you checked to see if there are any stored codes in the PCM with a code reader?
Let us know what you find.
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
Old Mar 21, 2008 | 06:47 PM
fordzilla01
Diane
No codes, and it alsmost feels like it runs a little bit rougher in this setting. Maybe you can elaborate on the "Contribution test" I have never heard of that before. After running for about 2min or so all is good. The truck runs great otherwise, in fact I am VERY impressed with the tuner. I am just trying to figure out this issue... If it were oil getting past the injectors then logic would tell me that it "SHOULD" do this in all of the tune options.
Old Mar 21, 2008 | 06:53 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
On edit:
You are starting it in the 120 so after a while of running in that tune the oil is emptied out from sitting. A contribution test is for the injectors and will see if the injectors are good or not.
Give Jody a call on Tuesday. He is out of town and will be back in the office on Tuesday. Shoot him an email also and ask him. he will be the best person to ask.
Diane
__________________
Old Mar 21, 2008 | 06:55 PM
fordzilla01
Exactly why it is strange. Give Jody a call on Tuesday. He is out of town and will be back in the office on Tuesday. Shoot him an email also and ask him.
Diane
Thats great, I appreciate your help. Have a wonderful weekend.
Old Mar 21, 2008 | 06:59 PM
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
wow, you're a fast poster...
I thought of something else ^^^^^
__________________
Old Mar 22, 2008 | 12:58 AM
fordzilla01
Not so fast this time... but what was the other thing you thought of?
Old Mar 22, 2008 | 04:07 AM
ron's power stroke
she Edited post 11 of what she thought of while you was posting post 12...
psd96
Aug 4, 2012 12:16 AM
jeff299
15
Jan 18, 2012 06:59 AM
Spool&Go
62
May 17, 2011 12:41 PM
H1449-6
Nov 13, 2008 01:05 AM
hdman6
Feb 8, 2007 08:13 PM
