Water Leak?
Old Mar 20, 2008 | 10:11 PM
TruckoffFord's Avatar
TruckoffFord
Water Leak?
I have a 99 F250 4x4 SD 320K that is loosing water. I could find no water leak; so, I took it to a Ford dealer and they have been unable to find a leak. It was pressure tested hot and cold.
I have added water to the resevior several time. I know there is a problem.
One doesn't go for months without putting water in to all the sudden adding water several times in a few days. When I first noticed it, the reservior bottle was half empty ( or half full if you want to be optimistic about it).
There is no water in the oil.
TruckoffFord
Old Mar 21, 2008 | 06:25 AM
F350-6's Avatar
F350-6
Keep an eye on your dipstick to make sure your oil doesn't start getting fuller. If I had to take a wild guess, I'd say your water pump may be on it's way out. You can develop a small leak at the water pump that mostly drips on the road while driving, but a hot engine helps evaporate the water so there's no puddles in the driveway.
You can try starting it up cold, revving the motor a few times, shutting it off before it's warm and then crawl under the truck or use an inspection mirror and check for any signs of water around the pump.
Old Mar 21, 2008 | 07:26 AM
TruckoffFord
Thanks, I'll give it a try.
TruckoffFord
Old Mar 21, 2008 | 11:39 AM
cadetcommander20's Avatar
cadetcommander20
also look real close at the flange where your upper hose comes into the water pump that is where mine started leaking changed it for like $30 from napa
TruckoffFord
Jul 31, 2012 10:52 PM
TruckoffFord
Nov 15, 2011 01:03 AM
TruckoffFord
30
Aug 21, 2011 08:40 AM
TruckoffFord
Jul 25, 2011 05:34 PM
TruckoffFord
May 19, 2009 12:31 PM
