Door locks will not work
Old Jul 23, 2011 | 10:01 PM
TruckoffFord's Avatar
TruckoffFord
Have an 01 7.3 4x4. The door locks will not work , driver side or passenger door. I can hear it trying to lock when I try to lock on the driver's door, and when I try it on the passenger door; but the locks will not work on all 4 doors. Any suggestions?
TruckoffFord
Old Jul 24, 2011 | 12:30 AM
tj01536's Avatar
tj01536
Sounds like the lock actuators are bad, if you hear any of them trying to lock, you can almost rule out a lock switch. If it was the switch, none would work or even try
Old Jul 24, 2011 | 12:48 AM
binuya's Avatar
binuya
Here's a link to a fix: https://www.ford-trucks.com/forums/9...-pictures.html
I did the aluminum foil fix on mine a couple years ago, and they're holding up just fine.
Old Jul 24, 2011 | 12:51 AM
SpringerPop's Avatar
SpringerPop
What's your history with this truck?
Did you just buy it and find the door locks are inop, or have you had it a long time and it just started not working?
Good diagnosis requires we have some details, not just "They won't work".
Pop
Old Jul 24, 2011 | 06:39 AM
TruckoffFord
I Just got the truck. Have put in two new batteries, no other problems with truck.
Old Jul 24, 2011 | 11:33 AM
SpringerPop
Inside each electric door lock actuator motor there is a heat-sensitive variable resistor. Their purpose is to change the amount of current that passes through the motor if they get hot. It's something that would happen if your dog stood on the door-lock switch for more than a couple of seconds, and is to protect the motor from burn-out.
Over time, the value of that resistor changes, and eventually gets so high in value that enough current cannot pass to allow the motors to overcome the physical resistance to actuate the lock mechanisms.
Your fix will depend on how handy you are. Some folks take it to the dealer. A pricey fix, indeed!
Some buy new actuators from the dealer (or aftermarket), take the latch mechanisms apart and replace them. Still, spendy, though not for the labor.
Some of us take the actuators apart, pull out the motor, take it apart too, and "jumper out" that resistor. Virtually free to do, but not for the impatient!
How do you wish to proceed?
Pop
Old Jul 25, 2011 | 12:09 AM
TruckoffFord
Thanks for the info! But is it common for all four doors to go out?
My 03 had that problem with the left back door and I replaced it. It was not simple. Will I have to door it to all four doors or is there something common to all four doors - that I only have to do once! Ha ha
Thanks for the HELP!
TruckoffFord
Old Jul 25, 2011 | 12:51 AM
SpringerPop
Each door latch assembly has to come apart.
They all went out a little bit at a time, and they were all gone when you got it.
The only things in common to all of them are switches and relays.
Need a schematic?
Pop
Old Jul 25, 2011 | 02:29 AM
hotroddsl's Avatar
hotroddsl
It seems like if the PO had young kids all 4 will be bad, if no kids just the drivers door!
Jim...& fat Monty
Old Jul 25, 2011 | 06:20 AM
TruckoffFord
A schematic would help alot. Thanks, I would like one.
Old Jul 25, 2011 | 11:27 AM
SpringerPop
See your PM's for a PDF.
Pop
Old Jul 25, 2011 | 05:34 PM
Stewart_H's Avatar
Stewart_H
I love saving schematics, Marv!
Stewart
jc8825
Jun 4, 2011 11:27 PM
turborich
Aug 29, 2008 07:39 PM
Boose
Jul 1, 2004 09:40 PM
oldscout
Electrical Systems/Wiring
Jan 20, 2004 01:41 PM
