EGR HELP
Old Nov 14, 2011 | 10:28 PM
TruckoffFord's Avatar
TruckoffFord
EGR HELP
I have an 03 f350 srw cc Fx4 with 182k.
The EGR valve (original) is sticking throwing an engine light, on and off.
Should I just clean it or unplug it and remove the Throttle Plate?
Would the EGR cooler work better?
Would it cause problems with the turbo or other parts?
Remember it an early 03.
TruckoffFord
Old Nov 14, 2011 | 10:40 PM
bismic's Avatar
bismic
Personally I do not hate the EGR system like a lot of others do. I would bite the bullet and replace it, if you are sure that is what it is.
Old Nov 14, 2011 | 10:43 PM
Goingbroke's Avatar
Goingbroke
The EGR opens and closes depending on throttle position. You can't just remove it or the throttle plate without blocking off the exhaust side.I would buy the EGR delete kit or replace the EGR valve if it is an original.Are you sure that's what is throwing a check engine light? I think the 03 models won't throw a check engine light for the EGR valve.
Old Nov 14, 2011 | 10:44 PM
BLADE35's Avatar
BLADE35
You must leave the egr valve plugged in it affects fan operation
so clean it or replace it or deleate it the valve still needs to be plugged in with a deleate kit
what is the code you get
read this thread
Unplugged EGR VALVE & the problems that follow
https://www.ford-trucks.com/forums/9...egr-valve.html
Old Nov 15, 2011 | 01:03 AM
TruckoffFord
I took it to a friends shop and he read it. Didn't tell me the code just said it was the EGR valve.
I need to get a SCT xcal2.
I had an engine light come on about two weeks ago and I called him about it and he told me to bring it by. The next morning the light was gone. It came on again last week and I took it over and that when he read it. The next morning the light was out again.
TruckoffFord
WH 6.0
Oct 28, 2010 07:43 PM
clinter36
Sep 11, 2008 02:50 PM
JIM_C
Aug 11, 2008 11:37 PM
Fluid Power
May 30, 2007 12:32 AM
