1978 - 1996 Big Bronco
Rear axle
Old Mar 24, 2008 | 04:06 PM
Broncobudy's Avatar
Broncobudy
Unhappy Rear axle
Just 2 days ago, there was this discharge under the rear axle. Turns out, it was from the open hose which leads from the rear axle housing. A bunch of sludge came out. Kind of a bunch came out. This is new for me and I wondered if this was ok or if something else is wrong? Thanks.
Old Mar 24, 2008 | 06:22 PM
TimmyAbrams's Avatar
TimmyAbrams
have you been muddin lately or driven through any deep water? when was the last time you changed the diff fluid. Sounds like it is time. A couple of quarts of diff fluid and a tube of rtv will give you piece of mind.
Old Mar 24, 2008 | 06:23 PM
helirich's Avatar
helirich
The hose was probubly clogged with dirt. When the temp went up, the pressure blew it out. If it's been awhile, I would change the diff oil. Make sure the vent hose is clear.
b4hntn's Avatar
b4hntn
Here is my experience with the same thing..
https://www.ford-trucks.com/forums/5...rential+grease
Old Mar 24, 2008 | 06:54 PM
Broncobudy's Avatar
Broncobudy
Let me ask you, is it easy to change the diff oil?
Old Mar 24, 2008 | 08:46 PM
b4hntn's Avatar
b4hntn
Determine if it is a limited slip differential and purchase accordingly. LS requires friction modifier (stinks a lot) added to the grease. I get it at Ford. Just crawl under and remove rear cover. Clean the sealing surfaces good, wipe out the inside. Apply a bead of RTV per Haynes diagram, let it set per instructions on the tube. Reinstall cover, but do not be in a hurry to refill to let the RTV set more. Fill per capacity in your owner manual. I use a good brand of grease, some prefer synthetic.
