Sponsored by: Real Truck
Sliding window switch
Old Mar 19, 2008 | 05:45 PM
05lariatPSD's Avatar
05lariatPSD
I just got the pictures of my new company truck (should be here Friday) and I have a question for you experts.
The truck is a 2007 F250 Lariat 4x4 and the question I have has to do with the rear sliding window.
Our auto broker tells me that the truck has a power slider, on my 2005 the switch is located next to the rear sensor switch on the dash. In the picture I was sent, the 4x4 selector **** is next to the backup sensor switch.
So my question is...where is the slider switch for this truck. I just want to make sure it has a slider before it gets delivered. I'm pretty sure it does as it seems to have every option except brake controller, upfitters, and moonroof.
Old Mar 19, 2008 | 08:27 PM
05lariatPSD
Wow No one knows?
Old Mar 19, 2008 | 08:39 PM
99f250psd's Avatar
99f250psd
Just to the left of the rear sensor switch, but outside of the black panel you are talking about with 4x4 switch. I sense some excitement...
Old Mar 19, 2008 | 08:48 PM
josh04hdf250's Avatar
josh04hdf250
Yeah, dont use it too much though, the whole bit will quit working if you do.
Old Mar 19, 2008 | 08:52 PM
05lariatPSD
Not too much excitement since the 07 isn't much different than the 05 I'm turning in. It's just that I used the sliding window a lot on the 05 and the 04 I've been driving this week doesn't have the power slider and I am missing it.
If this truck doesn't have it, I'll tell the broker to get a different truck!
Here is a pic...I don't see the switch
Old Mar 19, 2008 | 08:59 PM
josh04hdf250
What about the radio? I'd be most concerned about it! haah! The switch should be right there by the 4x4 switch...
Old Mar 19, 2008 | 09:07 PM
05lariatPSD
The radio was on order at the dealer...Not a worry of mine.
But it's looking like no power slider. I find that is the best way to ventilate these trucks in the 110+ degree Arizona heat.
I just called our broker and they are going to look for another truck
Old Mar 19, 2008 | 10:31 PM
Big Boy Truck's Avatar
Big Boy Truck
It should be one of the three buttons to the left and below the 4X4 switch, just below the gear shift lever. Hope that helps!
Old Mar 19, 2008 | 11:18 PM
05lariatPSD
Those are the information display switches: info/setup/reset. Looks like no power slider on this one.
Old Mar 20, 2008 | 09:38 AM
Lonewolftx's Avatar
Lonewolftx
Wink Huh???
Well, if you would just look at the rear window,you will see if it has a manual snap latch or is just smooth. A pic of that will confirm what the truck has. This one, from this pic would make us all think there is no power option installed hence the manual.
Old Mar 20, 2008 | 09:49 AM
05lariatPSD
If you would just read the original post you'll see that I only had pictures of the truck. You'd also see that my 2005 has a slider so I would know what to look for if I could see the back window!!
Either way, it doesn't matter...I told them to find another truck.
notthemaniusedtobe
26
Apr 2, 2015 02:07 PM
blustang6614
Sep 18, 2013 08:01 AM
flat4vw
Jan 9, 2010 06:45 AM
bob_351
13
Jan 15, 2009 03:18 PM
Zebra
Oct 11, 2003 10:57 PM
