Fixed rear window seal compatible with slider?
Old Dec 29, 2009 | 10:56 PM
flat4vw's Avatar
flat4vw
Fellas,
I just yoinked the rear slider from my '84 cab before it went to the crusher - Now I want to install it in my brother's '95 that has a fixed rear window.
Does anyone know first hand if the fixed rear window seal in the '95 can be used with with the '84 slider? I'm getting conflicting information from the big-name parts catalogs - LMC shows a different part # for the fixed vs. slider seals, while BroncoGraveyard has one part # that works with fixed or sliding windows.
I haven't ran OE Ford part #s yet - just wanted to see if anyone has experience with this. I would LOVE to not have to buy a new seal.
Thanks,
Old Dec 30, 2009 | 03:38 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I don't know about the slider in an '84 but my '87 with a factory 4 panel sliding window has a much wider channel in the gasket for the window.
Most aftermarket sliders have a narrow flange on the outside so they will fit in place of a fixed glass.
No need to ask how I figured this out...
Old Dec 30, 2009 | 05:39 AM
TexasGuy001's Avatar
TexasGuy001
Are you sure its an OE window?
If its aftermarket like CR Lawrence then it will work with the regular gasket.
Old Dec 30, 2009 | 05:50 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
...Laurence....
http://www.crlaurence.com/crlapps/sh...&History=21770
Old Dec 30, 2009 | 06:03 AM
TexasGuy001
Oops......
Old Dec 30, 2009 | 06:19 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Just pointing the way for someone who may stumble across this thread later.
Old Dec 30, 2009 | 07:57 AM
flat4vw's Avatar
flat4vw
Good call - I'll have to check if it's OE or aftermarket.
Thanks!
Old Jan 8, 2010 | 02:45 PM
flat4vw's Avatar
flat4vw
Checked it earlier this week - the glass is stamped "Carlite" and the frame/seal combo looks thicker than the fixed window/seal on the '95. So I'm 99% sure it's an original Ford slider, and thus needs a slider-specific seal.
I'll report back when I buy & confirm it works.
Old Jan 9, 2010 | 04:19 AM
TexasGuy001
That sounds like an OEM window to me.
Old Jan 9, 2010 | 06:45 AM
dustybumpers's Avatar
dustybumpers
factory window has to use the factory rubber for the slider. aftermarket window has to use the plate window gasket. most aftermarket windows were used to replace the plate glass, that's why they were designed to use the smaller gasket, to keep the cost down.
Amish Ford
Jul 24, 2016 05:24 PM
dthut
Feb 23, 2016 11:45 AM
newfordy
2009 - 2014 F150
Jul 12, 2015 01:09 PM
SuperDuty93
Jun 27, 2012 05:17 PM
JefflovesF250s
Jul 9, 2009 11:39 AM
