I just got the pictures of my new company truck (should be here Friday) and I have a question for you experts.
The truck is a 2007 F250 Lariat 4x4 and the question I have has to do with the rear sliding window.
Our auto broker tells me that the truck has a power slider, on my 2005 the switch is located next to the rear sensor switch on the dash. In the picture I was sent, the 4x4 selector **** is next to the backup sensor switch.
So my question is...where is the slider switch for this truck. I just want to make sure it has a slider before it gets delivered. I'm pretty sure it does as it seems to have every option except brake controller, upfitters, and moonroof.
Just to the left of the rear sensor switch, but outside of the black panel you are talking about with 4x4 switch. I sense some excitement...
Not too much excitement since the 07 isn't much different than the 05 I'm turning in. It's just that I used the sliding window a lot on the 05 and the 04 I've been driving this week doesn't have the power slider and I am missing it.
If this truck doesn't have it, I'll tell the broker to get a different truck!
Well, if you would just look at the rear window,you will see if it has a manual snap latch or is just smooth. A pic of that will confirm what the truck has. This one, from this pic would make us all think there is no power option installed hence the manual.
If you would just read the original post you'll see that I only had pictures of the truck. You'd also see that my 2005 has a slider so I would know what to look for if I could see the back window!!
Either way, it doesn't matter...I told them to find another truck.
