Fuel tank mod
Tricks to get your money's worth
> > TIPS ON PUMPING GAS--GOOD INFO . I don't know what you guys are paying
> > for gasoline.Here in California we are also paying higher, up to $3.50
> > per gallon. But my line of work is in petroleum for about 31 years
> > now, so here are some tricks to get more of your money's worth for
> > every gallon.
> > Here at the Kinder Morgan Pipeline where I work in San Jose, CA we
> > deliver about 4 million gallons in a 24-hour period thru the pipeline.
> > One day is diesel the next day is jet fuel, and gasoline, regular and
> > premium grades.
> > We have 34-storage tanks here with a total capacity of 16,800,000
> > gallons.
> > Only buy or fill up your car or truck in the early morning when the
> > ground temperature is still cold. Remember that all service stations
> > have their storage tanks buried below ground. The colder the ground
> > the more dense the gasoline, when it gets warmer gasoline expands, so
> > buying in the afternoon or in the evening....your gallon is not
> > exactly a gallon. In the petroleum business, the specific gravity and
> > the temperature of the gasoline, diesel and jet fuel, ethanol and
> > other petroleum products plays an important role.
> > A 1-degree rise in temperature is a big deal for this business. But
> > the service stations do not have temperature compensation at the
> > pumps.
> > When you're filling up do not squeeze the trigger of the nozzle to a
> > fast mode . If you look you will see that the trigger has three (3)
> > stages:
> > low,
> > middle, and high. In slow mode you should be pumping on low speed,
> > thereby minimizing the vapors that are created while you are pumping.
> > All hoses at the pump have a vapor return. If you are pumping on the
> > fast rate, some of the liquid that goes to your tank becomes vapor.
> > Those vapors are being sucked up and back into the underground storage
> > tank so you're getting less worth for your money.
> > One of the most important tips is to fill up when your gas tank is
> > HALF FULL or HALF EMPTY. The reason for this is, the more gas you have
> > in your tank the less air occupying its empty space. Gasoline
> > evaporates faster than you can imagine. Ga soline storage tanks have
> > an internal floating roof.
> > This
> > roof serves as zero clearance b etween the gas and the atmosphere, so
> > it minimizes the evaporation. Unlike service stations, here where I
> > work, every truck that we load is temperature compensated so that
> > every gallon is actually the exact amount.
> > Another reminder, if there is a gasoline truck pumping into the
> > storage tanks when you stop to buy gas, DO NOT fill up--most likely
> > the gasoline is being stirred up as the gas is being delivered, and
> > you might pick up some of the dirt that normally settles on the
> > bottom.
> > Hope this will help you get the most value for your money.
> > DO SHARE THESE TIPS WITH OTHERS...
