power stroke trannies
Old Mar 16, 2008 | 04:56 PM
lowbed dud's Avatar
lowbed dud
would like to know if auto trannie in 00-03 f250 & f350 are newer modle then
in 99's, all with 7.3's, look to buy
thank's
Old Mar 16, 2008 | 04:59 PM
farmb0y's Avatar
farmb0y
They are all the same tranny from early '99 to '03 (4R100). They went to a newer 5 speed torque shift with the new 6.0L engines.
Old Mar 16, 2008 | 06:49 PM
lowbed dud's Avatar
lowbed dud
thanks for reply, freind had 99 250 lost 3 in 4yrs, but towed 5th 35ft, wife loaded to
the gill's, i have 24ft toy hauler around 6000lbs
Old Mar 16, 2008 | 06:52 PM
superduty4x4's Avatar
superduty4x4
Any idea if a torque shift will bolt to the 7.3 or is the bolt pattern different?
Old Mar 16, 2008 | 06:58 PM
Alpine6's Avatar
Alpine6
From what i've read, the torque shift "could be" mounted up, but all the electronics, programming and so on doesn't make it worth it. Do a BTS transmission and don't ever worry about it again.
Old Mar 16, 2008 | 07:03 PM
sflem849's Avatar
sflem849
Do a John Wood or BTS Transmission and call her good. They both seem pretty darn good to me so I would go to whoever is closer.
Old Mar 17, 2008 | 07:04 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The bolt pattern is different, but even if you could adapt it, how would you make it shift? The computer in the truck certainly can't operate a TorqShift, and the computer for the TorqShift also needs to be controlling the engine, and there isn't a computer compatible with a TorqShift and a 7.3L.
Old Mar 17, 2008 | 07:16 AM
sflem849's Avatar
sflem849
I guess you would need to run dual processors...
Old Mar 17, 2008 | 04:58 PM
superduty4x4
This is why I ask questions a lot! Just being curious, my truck already has a rebuilt trans so hopefully I won't ever be needing to put one in.
Old Mar 18, 2008 | 08:28 AM
Mark Kovalsky
How would you make that work? The TorqShift processor needs to be controlling an engine to control the trans.
Old Mar 18, 2008 | 09:38 AM
preppypyro's Avatar
preppypyro
Can a guy even get an aftermarket 5 speed auto for our older trucks at all? Im sure it would be pretty costly if we could, but that would be pretty awesome.
Old Mar 18, 2008 | 11:33 AM
Izzy351's Avatar
Izzy351
To me, "pretty awesome" is a $4000 BTS that Brian dares you to break. And if you do, he'll fix it. Why spend twice as much if you can get this kind of tranny & service at $4k??
Old Mar 18, 2008 | 02:55 PM
preppypyro's Avatar
preppypyro
Just because i would love to see how that fifth gear affects things!
Dont get me wrong i have no problem with a tranny that someone dares me to break, but I would love to se how a 5 speed auto would differ, then the 4 speed in my truck.
Old Mar 18, 2008 | 04:00 PM
Izzy351's Avatar
Izzy351
Yeah, it would be nice, but it would be a huge challenge making one work. Go try out a D-max or a 6.0. Not that big of a deal having the extra gear, IMHO. But then again, I don't tow heavy either. I'm thinking in that case, the 5th gear makes a much bigger difference.
