5.4l oil question
Old 03-16-2008, 12:03 PM
bayouboy's Avatar
bayouboy
bayouboy is offline
5.4l oil question
I have a 07 F250 2wd work truck with a 5.4. I change the oil every 5K. I am considering switching to synthetic blend, 5w20 Motorraft. Has anyone used this oil? Can I extend the oil change intervals? any good things, or problems? As I said this a work truck, and would like it to last as long as possible.
Old 03-16-2008, 12:18 PM
galaxie641's Avatar
galaxie641
galaxie641 is offline
I wouldn't extend intervals on it no matter what oil you use. I used 5w20 for about a year and felt it was just too thin and went back to 5w30, but I change mine at 4K no matter what.
Old 03-16-2008, 12:21 PM
rob188's Avatar
rob188
rob188 is offline
yeah i certainly wouldn't extend your intervals cause its a work truck, and i wouldn't think a synthetic oil would work anybetter on a regual 5.4 cuz its not a performance motor, a regular 5w20 would work just fine and if u want the extra protection in the summer use 10w30
Old 03-17-2008, 09:18 AM
bayouboy's Avatar
bayouboy
bayouboy is offline
Thank You for your insight. If anyone else has any input, please post it.
Old 03-17-2008, 10:18 AM
whimsey's Avatar
whimsey
whimsey is offline
According to used oil analysis Motorcraft 5W-20 on BITOG(bobistheoilguy.com) does real good in these engines doing a 5,000 mile oil change interval. If you want to extend the oci look at the used oil analysis section of BITOG to see how various oils performed. Then you can judge for yourself what's good for you.
Whimsey
Old 03-17-2008, 07:30 PM
vze2sgxa's Avatar
vze2sgxa
vze2sgxa is offline
I switched to 5W-20 about 40k miles back (from 5W-30) due to the Ford TSB, #02-1-9. Better mileage, better wear properties, better starting. I use Motorcraft Synth Blend, 5W-20, cheap at Walmart.
Just don't dilute it with seafoam.
Old 03-17-2008, 08:07 PM
YoGeorge's Avatar
YoGeorge
YoGeorge is offline
Everybody likes Motorcraft 5W-20...
...except maybe Amsoil dealers 8-)
I've used it in my '02 E150 4.6 since new and it's been just great. I would probably stick with 5k change intervals, which I think is the severe duty official change interval.
Motorcraft 820S filters, for a number of reasons, are also the best thing to use on the mod motors.
And if you properly document the changes, there will never be any question regarding the new truck warranty--but I would use the Motorcraft oil and filters even if warranty were not a consideration.
There's an oil forum on this page and you're welcome to do some more reading if you'd like.
George
Old 03-21-2008, 11:53 AM
redford's Avatar
redford
redford is online now
Received 1,578 Likes on 921 Posts
5W20 is the recommended viscosity for the 2007 F-250 5.4L V-8. It will say so on your oil filler cap.
I change my oil at 3000 mile intervals if using conventional oil, or at 5000 mile intervals if using synthetic.
Old 03-21-2008, 08:43 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
I've used the Motorcraft 5w20 syn blend since I got my truck and have had no problems in 76K miles.
Old 03-24-2008, 11:43 AM
bayouboy's Avatar
bayouboy
bayouboy is offline
Thank you for the input. I think I am going to stick with motorcraft 5w20 for now.
Old 03-24-2008, 08:32 PM
ExpySport's Avatar
ExpySport
ExpySport is offline
Been using the Motorcraft 5W-20 Synthetic Blend since day one on my 2002 Expedition, 5.4L with the FL-820S Motorcraft oil filter. I change my oil every 5K and I'm sticking with it.
Old 03-29-2008, 09:17 PM
carls 250's Avatar
carls 250
carls 250 is offline
I switched to 5w20 full synthetic from reg. 5w20 7 noticed a puff of smoke @ start ups & used about 1.5 QTS. every 3000 miles. Went back to reg. 5w20 no problems.
Old 04-10-2008, 06:32 PM
HammeredFlat4's Avatar
HammeredFlat4
HammeredFlat4 is offline
Never use anything thicker than 5w-30 and never use anything but a Motorcraft oil filter unless you want to buy a new motor! The idiot I bought my truck from used thick oil and cheap oil filters, it ran great with 100k on the clock but lost oil pressure 3 days after I bought it with no warning. Ford will voild your warranty if you use anything but a Motorcraft filter. I have a friend that is a parts manager at Ford, the cheap oil filters come apart and clog the check valve/oil pump.
Old 04-10-2008, 07:51 PM
BLK94F150's Avatar
BLK94F150
BLK94F150 is offline
Motorcraft 5w20 is cheap and it's made for your truck, so why not?
Why use any other viscosity other than what is recommended?
Mike
Old 04-12-2008, 07:24 PM
suzuki0702's Avatar
suzuki0702
suzuki0702 is offline
are you serious dude? warranty is only good for 36k miles first of all. second of all ive been using stp/ firestone/ fram filters for 70kmiles, and on countless other vehicles.
to the O.P. question. ive never heard of anyone having a problem with there engine in result to the brand of oil they use. its all personal preference, however do not used anything heavier than 5w-30. 10weight oils are toooooo thick for these tighter clearance motors. ford doesnt reccomend it for fun!
Quick Reply: 5.4l oil question
