06 6.0 problems
Old Mar 15, 2008 | 12:48 PM
OCD's Avatar
OCD
Angry 06 6.0 problems
I have a 2006 350 w/ 39k miles. I am experiencing multiple problems which are: When at a steady speed between 55 and 65 it feels like the eninge is "surging" feels like hitting bumps in the road, which are not there. The second problem is that some times when under heavy acceleration or under load, theres a high pitched noise coming from what sounds like the turbo, sounds kind of like air leaking. And yet another problem is very hard starting when its not even that cold out, and when its cold out if its not plugged in it can take 6-7 attempts to get it to start and not die. And to top it all off i think the ignition safety switch on the gear shift lever is starting to fail.
Any thaughts or suggestions would be greatly appriciated.
Thanks, Sean.
Old Mar 15, 2008 | 01:05 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
06 with 39K I would take it in and use the $100 deductible on the engine warranty to get it up to par.
When was the last fuel filter change? Did the problems start after a fuel fillup? (bad fuel)
Old Mar 15, 2008 | 01:57 PM
conger's Avatar
conger
I'd agree... I'd change those fuel filters right away. If no change get her in under warranty. Might be some injector issues.
Old Mar 15, 2008 | 08:44 PM
salesman112's Avatar
salesman112
Thanks, Sean.
i agree with the first two, i forgot to change my fuel filters and had similar problems, surging, troulbe starting, but not the noise. i would change the filters yourself first then take it in. otherwise they will change filters first and charge you 150 dollars. then they will got to the 100 deductible to fix any other problem.
good luck
Old Mar 15, 2008 | 09:47 PM
Jakesrodshop's Avatar
Jakesrodshop
any check engine lights? sounds like turbo veins maybe clogged also
Old Mar 15, 2008 | 10:05 PM
MD11Drvr's Avatar
MD11Drvr
I had a similar acting 6.0 when the EGR valve was sticking. I have run Diesel Kleen with most tanks or at least every other tank and no problems since and that was 40K ago.
Old Mar 16, 2008 | 10:34 AM
JROSCO6's Avatar
JROSCO6
My truck was doing the same thing surging and they replaced 3 injectors. But now its doing the same thing again. I replace the filters every 15k. Just have to find time to get it into the shop again. I just hate to have my truck sitting there. Last time it was in I made the apt. for a Monday. They didnt actually start work on it till Thursday and that was probly because i told them i needed the truck for the weekend if not it would have sat there another week.
Old Mar 16, 2008 | 10:47 AM
BobsF350's Avatar
BobsF350
I live in mi and am 8 miles from the only ford dealer thats open monday morning 7am-friday night 6pm 24Hour service and parts.and they even have mechanics working
Old Mar 16, 2008 | 02:09 PM
bismic's Avatar
bismic
JROSCO6,
Do you have any idea what might be causing the injector problems?
Since you have some gauges, do you monitor fuel pressure? It would be interesting to know what was going on w/ the pressure.
Also, do you use any fuel additives for lubricity?
Last - have you ever run out of fuel AND do you use the "key cycle" procedure before starting up after a filter change?
Sorry about the problems you guys are having and (to the OP), sorry about hijacking the thread a little ............. I really hate to hear about injector problems that can't be traced to anything!!!
Old Mar 16, 2008 | 06:09 PM
05f350sd's Avatar
05f350sd
BobsF350 - Where is this dealership - I am in michigan too and would love to find this dealership. Thanks!
Old Mar 17, 2008 | 12:12 PM
OCD's Avatar
OCD
Talking
Well i changed the fuel filters and i think it solved that problem. Now my next concern is that high pitched air escaping noise that i fear is coming from the turbo. And on a side note, If i ever meet the engineer that thaught it was a better idea to put the fuel filter on the inner frame rail under the front floor board, next to the transmission cross member instead of just moving it back 5 feet on the frame i am going to..well we'll just keep what i'll do as a suprise for that....person.
Old Mar 17, 2008 | 12:47 PM
denman81's Avatar
denman81
glad ya got her fixed. as far as the air escaping look at the blue boot coming off the turbo. make sure it didn't blow off or have a tear in it.
Old Mar 17, 2008 | 08:28 PM
BobsF350's Avatar
BobsF350
Russ Milne Ford Hall road and Gratiot
Old Mar 17, 2008 | 08:54 PM
JROSCO6's Avatar
JROSCO6
Bismic, The tecs have no idea. I have never run out of fuel and i do cycle the key 5 or 6 times after replacing Motorcraft filters. I was using an additive (Power Service)but I have not in a while. No fuel pressure guage.
Old Mar 17, 2008 | 09:16 PM
bismic's Avatar
bismic
JROSCO6 -
Thanks for the reply. I sure hope this will be the last round for you to get the injector situation / surging resolved permanently.
I am very anxious for April to get here. They should have new software for the DashDAq (I am told). The thing I am looking forward to the most is being able to track fuel pressure (and later on, installingthe return regulated fuel system).
Yahiko
Feb 3, 2014 04:17 AM
sean23johnson
Jul 13, 2011 09:21 PM
scraig
1978 - 1996 Big Bronco
Mar 7, 2008 08:59 PM
seanh
Aug 18, 2006 11:15 AM
