Is a chip safe
Old Mar 17, 2008 | 08:14 PM
D8chumley's Avatar
D8chumley
Resident smarta$$
No you should probably get headstuds, then gauges, THEN a chip, preferably an SCT, which seems to be the tuner of choice here, from either Spartan or Innovative. Search them and you will find more than you'll want to read
Old Mar 17, 2008 | 09:00 PM
3000 FPS's Avatar
3000 FPS
I second that motion. A chip can make the exhaust gas temps higher.
Old Mar 17, 2008 | 10:07 PM
John with beastly 302's Avatar
You must also realize also that, yes studs will be much stronger but you still run the risk of a failure in other systems, for example in the fuel system because of the extra load on the fuel injectors, and should I even mention fortifying the 5R110W. I have been told that the 6.0 only has like 10 or 12 head bolts per head or studs whatever your flavor, were as the 7.3 had 18 someone correct me if I am wrong.
Basically what I am getting at is the 6.0 was not designed to be pushed to the limit, it is ba##s to the wall stock . So if you do decide to tune just remember it is a gamble you may be alright or you may not be, and you will also be sacrificing longevity but I guess for those who can buy a new truck every couple of years it does not really matter.
Old Mar 17, 2008 | 10:16 PM
doubledee715's Avatar
doubledee715
that's what dj's fuel kit or itp's fuel kit is for as well as fass pumps or airdog pumps. Now you're in better shape then you were while in stock form.
wolfrum
Computer Chips & Tuners
Jun 2, 2009 10:37 AM
nantruckit
Jan 29, 2006 11:46 AM
Rich in CO
Dec 27, 2005 06:01 PM
racer956
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Mar 21, 2005 11:22 PM
gburkett
Aug 13, 2003 08:18 PM
