Chips & Tow safe mode?
Old Dec 27, 2005 | 11:38 AM
Rich in CO's Avatar
Rich in CO
Ok folks I'm thinking of upgrading from my BD75 chip and I'm looking into a multi stage chip. What I can't figure out is what does the tow safe stage on a chip do for you when towing?
Thanks
Rich
Old Dec 27, 2005 | 11:40 AM
Fire Rooster's Avatar
Fire Rooster
helps keep EGT's down in a more controllable range while the truck is under load
Old Dec 27, 2005 | 04:13 PM
CAT_man_963's Avatar
CAT_man_963
I think I've heard of "tow safe" referring to tuners, more than chips - but reguardless - it's basically just a lower horsepower tune, that, like FireRooster said, keeps your EGT's, and tranny temps for that matter, safer than towing on a high HP, race tune.
Old Dec 27, 2005 | 04:18 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
in the world of diesels, more power is only going to be made by adding more fuel. this in turn adds more air to the mix because there is more exhaust spinning through the turbo. more fuel= more heat, more heat= unsafe for towing. the "tow-safe" is usually 45-60 hp over stock, usually power settings 1 and 2. leave 3 for light towing, and 4 and 5 for unloaded "power-trips." the lower settings are also less stressful on the transmission, especially when it is trying to pull more weight.
since you have a chip already, i am assuming you have gauges to monitor temperatures and boost. when towing, you do not want to see over 1250* pre-turbo temperatures. sustain anything more and you're asking for trouble.
Old Dec 27, 2005 | 04:27 PM
Rich in CO's Avatar
Rich in CO
Thanks for the info guy's. I have guages, and a 75hp chip in right now and when towing my 8,000lb TT up the hills in Colorado I can move up the passes around 50 mph while only pulling about 1100* EGT's per turbo.
Would I see any lower temps with a chip that has a tow safe mode?
Old Dec 27, 2005 | 04:33 PM
PowerstrokeJunkie
most likely. but you wouldn't have the extra 20-35 horsepower you have now. there is a 40hp "heavy tow" setting, and a 60hp "regular/light tow" setting. i would opt for the 60hp since your temps are pretty good as it is.
what brand chip are you thinking of? i recommend DP tuner, im getting one.
Old Dec 27, 2005 | 04:38 PM
CAT_man_963
If you're seeing 1100 towing up a pass - I don't see a problem with that. You can run a PSD at 1200* all day long - so 1100 is pretty good considering the load you have behind you. You could drop egt's with a lower program, but then you're loosing pulling power too. Personally, I tow in whatever program gives me acceptable egt's for the load I am pulling.
Old Dec 27, 2005 | 05:55 PM
Rich in CO's Avatar
Rich in CO
Right now I have a Bully Dog 75hp chip, and she works fine, but I'm not sure I get the whole 75hp after reading some past threads. I have been hearing great things about Jodi's chips, and that is what I was looking at. I still might I just might but not add a tow safe mode and just go with some thing like 80hp max and watch my gauges.
PS how come the mods on my truck don'y show in my post like your's? I have them listed in my Sig, and the box is checked.
Old Dec 27, 2005 | 06:01 PM
PSNut's Avatar
PSNut
uneed to be a Supporter to have them displayed...just click on a blue "supporter" emblem and send $16 to become a supporter
obs870
Jun 25, 2015 07:20 AM
Royson12
83
Oct 11, 2014 08:53 AM
RRTREE
Mar 9, 2014 10:21 PM
johnny diesel
Dec 9, 2013 08:23 PM
MikeSDK
May 16, 2012 09:44 AM
