Egr Delete
Old Mar 17, 2008 | 11:06 AM
mudracer80's Avatar
mudracer80
My cooler had already failed, thats why I just did away with it. I guess it would of worked the same just blocking off the flange on the cooler but no I know there is no way it can fail
Thanks about the write up. I dont know why the pics wouldnt come up, Its now in the 6.0 tech folder on ford-trucks.com with the pics.
Old Feb 8, 2009 | 09:30 PM
hacksaw830's Avatar
hacksaw830
Joey,
How thick is the blockoff plate that you made? what material is that looks like sheet metal? also did you use a freeze plug for the other end? what size? will I need to weld the round piece in?
Originally Posted by Joeymt3
notice lower EGT's and slightly better fuel economy. My CEL didn't come on. if you do this mod and the CCV reroute mod you can keep your intake clean. i used 5 can of carb cleaner to clean the manifold once i removed it from the truck.
here is the pic of the front block off plate that i made, the other one is just a circle.
i
Old Feb 8, 2009 | 10:55 PM
Joeymt3's Avatar
Joeymt3
I think that you should weld in the round piece in the up pipe. the other piece can be installed with silicone on both sides.
the piece that I made, I cut from a larger sheet of 1/16th or 1/8th thick. I can't remember. I made sure it was thick enough though, i used the same metal for the up pipe.
Old Jun 20, 2010 | 12:35 PM
Tat2 Man's Avatar
Tat2 Man
New to this site can't really find anything can some one please post a link to the pics in the write up done in this thread thanks
Old Aug 2, 2010 | 08:45 AM
scrambler304's Avatar
scrambler304
Also new to the site. Just bought a 2006 F350 with the 6.0 Friday. 6.5 miles away from the ford place the Check Engine Light comes on and I did a sharp (sharp for a LB F350 CC) u-turn back to the Ford place. I knew they had replaced the ERG valve before I bought it becaused it had been deleted. Thanks to this site and forum I knew this was a common delete on 6.0s. After returning and running a check it was found the cooler and what ever else had been removed. I kept the truck with CEL on and went on my way. How can I check that the delete was done correct and what tuner is recomended to turn off the CEL? I still want the CEL to work for everything else just not "Low/No Flow EGR"? Thanks for the help..
akblackfoot
May 30, 2017 11:52 AM
Strokin-A-2010
Dec 10, 2016 08:58 AM
white Buffalo
Sep 12, 2015 10:21 AM
troy676
Jul 6, 2015 01:25 PM
glb4x4van
Sep 1, 2013 02:20 PM
