Another Coolant Pressure Question
Old May 28, 2017 | 05:02 PM
akblackfoot's Avatar
akblackfoot
Is there a possibility on an egr deleted truck, but the egr is still in place with coolant passing through it, that the egr cooler can get clogged and cause pressure in the degas bottle?
Old May 28, 2017 | 05:17 PM
LCR's Avatar
LCR
Im confused how you have an EGR delete but still have an EGR.
Old May 28, 2017 | 05:21 PM
bismic's Avatar
bismic
The only ways I know of are 1) if it messes with the fan operation and that generally was on early model years IIRC, OR 2) if the vent hose is plugged (but I thought that that usually takes more heat than you would get if the exhaust gas flow path was blocked off).
Old May 28, 2017 | 05:54 PM
akblackfoot
It's done quite often. Weld a plug in the egr cooler, up pipe bypasses the egr cooler. I guess I didn't realize until recently that coolant was still going through it though.
Old May 28, 2017 | 05:55 PM
akblackfoot
Where is the vent hose?
Old May 28, 2017 | 07:50 PM
bismic's Avatar
bismic
It is the hose that ties into the right side (when sitting in the drivers seat) of the degas bottle. Comes of the manifold beside the oil filter.
Old May 28, 2017 | 09:12 PM
LCR's Avatar
LCR
Ahhh, I would call that an EGR block off.
Is the only path for the coolant to make a loop through the EGR? if not it should take the path of least resistance and eventually bypass the EGR completely as it clogs.
Old May 28, 2017 | 09:18 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Is the only path for the coolant to make a loop through the EGR? ....eventually bypass the EGR completely as it clogs.
Pretty much. If the EGR cooler somehow clogged it would cut the oil cooler out of the loop at that point. From the water pump it flows into the top of the block from the front cover, through the oil cooler, up through the EGR cooler, then into the top of the front cover. The 2003 coffee table book shows system flow. The reverse is much more common, the oil cooler clogging and nuking the EGR cooler, I don't think I've ever heard of an EGR cooler clogging. Rupture yes, clog not really.
I'm gonna say no, unless the welds are so shoddy they aren't stopping exhaust.
Old May 29, 2017 | 12:08 PM
TooManyToys.'s Avatar
TooManyToys.
I've never heard of an egr cooler getting clogged, only the oil cooler.
Is it possible that a poorly blocked EGR cooler with a small amount of exhaust gasses flowing through the cooler to overheat a reduced amount of coolant flowing through due to a clogged oil cooler to create a high pressure boil over? Well anything is possible.... but that a a pretty stacked set of events.
Old May 29, 2017 | 04:00 PM
Per4mance's Avatar
Per4mance
A head gasket would take time to build pressure,it just wouldn't give pressure that fast. If it did, it would be a badly cracked head. My bet is the cheap EGR cooler delete. Either way it's going to have to come apart,sorry,I had to say it. I'd rather have to pull the intake than the heads.Test the EGR cooler with the one end plugged on the coolant side and air pressure to the other and put it under water. That will give you the true story.
Old May 29, 2017 | 04:16 PM
texastech_diesel
Token Redneck
Maybe if it's a freeze plug stealth delete? Those can burn through eventually. I just can't imagine someone putting an SS plug into the exhaust side of the EGR cooler and welding it so badly that it leaks enough in the 40-50psig range to register on a coolant pressure sending unit, after the EGR cooler blew after the delete.
Side note, even if the EGR cooler/Oil cooler loop was 100% clogged...... are the restrictions in the rest of the cooling system enough to build pressure? The water pump doesn't build pressure, the movement of the coolant through the smallest bottleneck would. If the water pump is sized to move coolant through the block and radiator with an open t-stat, I'm not buying that any clog in the coolant system could build pressure in the degas bottle at all. Even if the deareation line was removed coolant flow would push a gas bubble back to the pump and into the degas bottle. It has to be headgaskets or the EGR cooler, nothing else could produce pressure in the cooling system at the 18psi it's designed to run at.
Old May 29, 2017 | 04:36 PM
akblackfoot
I'm not understanding how the egr cooler delete could cause pressure. There is no exhaust going to the egr cooler. It's welded and I have a one piece up pipe kit so exhaust doesn't even flow to the weld.
Old May 29, 2017 | 04:50 PM
TooManyToys.
Then the only one way to build pressure are the head gaskets or extreme heat. Even if the oil cooler was fully clogged flow would continue to the normal engine passages.
Old May 29, 2017 | 04:54 PM
wedge542's Avatar
wedge542
How much pressure are you seeing after releasing the warmup pressure?
Old May 29, 2017 | 10:18 PM
akblackfoot
I didn't release any warmup pressure but too much.
