another oil leak question
Old Mar 11, 2008 | 09:33 PM
Flea's Avatar
Flea
Sorry to be repetitive from othe posts but ...
I have a slow oil leak down the back of my motor. It is dripping from the bell housing of the tranny.
It is oil and it started after i installed my hpx line.
I lost some oil into the valley and it has pooled up under the turbo.
however something continues to leak and I have checked and rechecked the new hpx hoses, they are very tight with the box end wrench I used. I don't see or feel oil coming from them.
I am wondering if something else is leaking. I never had an oil leak before the hpx.
please help any ideas.
Fletch
Old Mar 11, 2008 | 09:51 PM
scatgo's Avatar
scatgo
Did you clean up the valley yet? There are two orings between the turbo pedestal and the motor they can be leaking. Or look at the rod that goes to the EBPV.
Old Mar 11, 2008 | 10:04 PM
Flea's Avatar
Flea
ahh, tell me more about the EBPV. I recently pulled that(electrical connection) off,
Old Mar 11, 2008 | 10:26 PM
scatgo's Avatar
scatgo
The rod that opens the valve has a piston on it inside the pedestal. The seal on the piston will leak and let oil come out from around the rod. The seal is like a hard plastic that will wear out the soft aluminum bore so replacing the seal might be a waste. What most people do is remove the piston and tap the rod hole to take what i think is a 1/8 NPT plug. It has been a long time since i did it so Iam not sure on the size of the plug.
Old Mar 11, 2008 | 10:36 PM
Flea's Avatar
Flea
where is this in relation to the electrical connection?
anyone have a picture?
Old Mar 11, 2008 | 10:37 PM
scatgo's Avatar
scatgo
O, Yea most people also remove the EBPV also. If you go to webshots and do a search you should find many pics on this subject. Gutting the EBPV is easy but getting the turbo off to get to the pedestal is a major PITA so you might want to make sure this is where you oil leak is before you start getting into all this.
Old Mar 11, 2008 | 10:38 PM
Flea's Avatar
Flea
Can I verify by plugging the EBPV back in?
scatgo's Avatar
scatgo
Look under turbo from the passanger side.
Old Mar 11, 2008 | 10:42 PM
scatgo's Avatar
scatgo
Maybe. I have seen oil leaking from the rod hole when I would first start a cold motor. If it is leaking you should be able to see stains under the rod hole. And cleaing up the valley under there will help. SORRY but I just realized I may have had it unplugged when I saw the oil ozzing out so not sure if plugging in will help.
Old Mar 12, 2008 | 12:56 AM
kawa's Avatar
kawa
Regardless if the oil is coming from a puddle or from some other place you HAVE to get the valley clean and dry.
Use a roll of paper towels and jam them evey place you can to mop up the oil, spray some brake Kleen in the valley. Once clean then use a GOOD flashlight and a mirror and you will find that leak.
Once found (leak) and you are in need of further assistance, give us another call.
Rog
Old Mar 12, 2008 | 06:40 AM
scatgo's Avatar
scatgo
You might not even have a new leak. It can oil still finding its way to the ground from when you did the HPX.
Old Mar 12, 2008 | 07:10 AM
Flea's Avatar
Flea
I figured it was a new leak by the oil loss I am experiencing according to my dipstick.
Diesel cat
May 26, 2012 11:09 PM
deerslayer165
May 20, 2010 10:37 AM
87 F-150 I6
20
Oct 29, 2009 05:29 PM
Flea
Mar 27, 2008 03:49 PM
cef2lion
Apr 24, 2006 03:48 PM
