SS HPX from ITP, need help
Old Oct 26, 2008 | 03:35 PM
87 F-150 I6's Avatar
87 F-150 I6
I just got my SS HPX, what will I need to do to install it. Will I need to add oil to the system or will it not leak out that much. How snug do I need to tighten it, will I need to use any Teflon tape?
Old Oct 26, 2008 | 03:45 PM
boone1965's Avatar
boone1965
I installed mine with no special tools or added oil. remove the two plugs from th eheads, one per side. Clean the area in th ehead from any sealer and old o ring part. I then added the fittings to th ehead and made sure to wet the o ring with oil first then just used a deep well socket to tighten the fittings in. I then placed xover tube on loosely at each end the tightened them down and put my parts back on then nstarted it and checked for oil leaks and had none. It was pretty straight forward and painless.
Old Oct 26, 2008 | 03:48 PM
87 F-150 I6
so not torque specs, I don't what to crack the block but I don't want to have oil leaking ether.
Old Oct 26, 2008 | 03:49 PM
USAF CCM's Avatar
USAF CCM
I would not use tape or anything else on those fittings. When I installed my crossover line, no oil spilled out. I snugged mine down pretty tight.
A word of caution: keep an eye out for leaks. After one year on the truck, I was returning from deer hunting, when I got home I discovered oil all over the backend of my truck. One side of the HPX hose started to fail at the fitting. I was glad it didn't blow completely; the truck would've shut down immediately at that point. Best of Success! V/r Les
Old Oct 26, 2008 | 03:56 PM
Izzy351's Avatar
Izzy351
I snugged mine down "pretty good", but ended up with a leak there as well. 3000psi oil shooting by the O-ring tore it up in short order. I snugged it down after replacing the O-ring tighter that time, and it's been good for over a year now. I didn't get a torque value for you, but I had to put more on it than I expected. I know that's all vague, but hope it helps.
Old Oct 26, 2008 | 04:16 PM
PaysonPSD's Avatar
PaysonPSD
I couldn't find the torque spec for an HPO rail plug but did find it for the ICP. Since it is in an HPO plug port that would be what I would start with. ICP torque spec is 22 lb/ft. In this chart it is called "Oil Injection Pressure Sensor". If it leaks tighten it slightly. The nut that holds the SS tube to the JIC fitting boss just needs to be real snug. Better to be on the loose side to start then to over tighten to begin with.
<TABLE cellSpacing=0 cellPadding=3 border=1><CAPTION>Torque Specifications </CAPTION><TBODY><TR><TH vAlign=bottom align=middle>Description</TH><TH vAlign=bottom align=middle>Nm</TH><TH vAlign=bottom align=middle>Lb/Ft</TH><TH vAlign=bottom align=middle>Lb/In</TH></TR><TR><TD vAlign=top align=left>Oil Pump Drive Gear Retaining Bolt</TD><TD vAlign=top align=middle>129</TD><TD vAlign=top align=middle>96</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Oil Deflector Retaining Bolt</TD><TD vAlign=top align=middle>12</TD><TD vAlign=top align=middle>9</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Fuel Injector Retaining Bolt</TD><TD vAlign=top align=middle>13.6</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>120</TD></TR><TR><TD vAlign=top align=left>Oil Drain Plug</TD><TD vAlign=top align=middle>6</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>54</TD></TR><TR><TD vAlign=top align=left>Oil Injection Pressure Sensor</TD><TD vAlign=top align=middle>29</TD><TD vAlign=top align=middle>22</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Drive Gear Access Cover Retaining Bolts</TD><TD vAlign=top align=middle>21-32</TD><TD vAlign=top align=middle>16-24</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>High-Pressure Oil Pump Mounting Bolt</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Oil Injection Pressure Regulator Valve Nut</TD><TD vAlign=top align=middle>6</TD><TD vAlign=top align=middle>—</TD><TD vAlign=top align=middle>55</TD></TR><TR><TD vAlign=top align=left>Oil Injection Pressure Regulator Body</TD><TD vAlign=top align=middle>47</TD><TD vAlign=top align=middle>35</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>Fuel Filter/Water Separator Mounting Bolts</TD><TD vAlign=top align=middle>31</TD><TD vAlign=top align=middle>23</TD><TD vAlign=top align=middle>—</TD></TR><TR><TD vAlign=top align=left>High-Pressure Oil Reservoir Retaining Bolts</TD><TD vAlign=top align=middle>24</TD><TD vAlign=top align=middle>18</TD><TD vAlign=top align=middle>—</TD></TR></TBODY></TABLE>
Old Oct 26, 2008 | 04:49 PM
87 F-150 I6
22 lb/ft is kinda loss but I will try it and if it starts leaking I can tighten it.
Old Oct 26, 2008 | 05:07 PM
PaysonPSD's Avatar
PaysonPSD
Fittings with o-rings don't seem to need the torque we think. You can easily damage the o-ring by over torqueing. Like mentioned before lube the new o-rings.
Old Oct 26, 2008 | 06:26 PM
87 F-150 I6
ok, I guess it would not need that much, just sounded weak. I will keep you all updated.
Old Oct 26, 2008 | 06:31 PM
Izzy351's Avatar
Izzy351
Yeah, that does sound low. I'm quite sure I put a lot more than that on mine, even before it leaked...
Old Oct 26, 2008 | 07:02 PM
PaysonPSD's Avatar
PaysonPSD
I do agree with you Joe. It doesn't sound like enough torque. The ICP is subjected to he same pressure though. I can't find a torque spec for the HPO line fittings at the head. If I could find that in the worhshop manual then I could compare it to the spec for the ICP. I wonder if there is a misprint. The 29 NM converts to 22 lb/ft so that would be a misprint as well.
Old Oct 26, 2008 | 08:48 PM
IABill's Avatar
IABill
Wink
Use red locktite, the removable type and ou will have no problems provided you snug them down nicely.
Old Oct 26, 2008 | 09:09 PM
Tenn01PSD350's Avatar
Tenn01PSD350
It is a feel. Torque that sucker down on that oring to where you feel it has compressed it tightly without squeezing it, or risk blowing out the oring like Joe described. Too loose can be bad because you can destroy the oring. Too tight is really hard to achieve unless you have a poor feel for these things. Snug it down good without cranking on it.
You will know when you are cranking on it because it goes from a good snug feel to a cranking one. Once it begins to snug, keep turning until it feels different. Done. IOW, I used no TQ wrench.
Old Oct 26, 2008 | 11:02 PM
bdrummonds's Avatar
bdrummonds
I also used the red loctite on my HPXover bosses.
Dont ever use teflon tape on the oil system, if a small peice comes off, it could clog the tiny oil passages in an injector.
Old Oct 27, 2008 | 01:22 AM
ron's power stroke's Avatar
ron's power stroke
http://www.itpdiesel.com/other/KCM/S...structions.pdf
