HPX leaking
Old May 26, 2012 | 09:54 AM
Diesel cat's Avatar
Diesel cat
HPX leaking
found some oil under the ol powerstroke and traced it to a fittings on the hpx cross over. I read to use locktite 680 on the fittings, but having trouble finding it localy. we do any of you guys know what napa or orileys has that's compatible.
Old May 26, 2012 | 05:56 PM
mjonesjr's Avatar
mjonesjr
Get the cross over line off and put the original plugs back into the heads before it blows and catches the truck on fire.. The cross over tube isn't all its cracked up to be until you get into the high HP range.
Old May 26, 2012 | 06:08 PM
srteach's Avatar
srteach
I differ from the opinion of Mrjonesjr. The HPX is useful for reducing the rough firing on the 6/8 part of the cycle. It smooths the engine.
In answer to the actual issue, go to ford and get the fuel rail o-rings and put a pair in. They are also available at dieselorings.com
Old May 26, 2012 | 07:41 PM
Diesel cat's Avatar
Diesel cat
thanks for the reply, tuesday I'm going to call diesel o rings and get another set.
Old May 26, 2012 | 07:56 PM
6.0techwannabe's Avatar
6.0techwannabe
yup,hpx does smooth the idle. hpop o-ring kit comes with a cute little tube of the correct stuff. if its time for servicing the hpop...use that stuff. i had a problem with mine vibrating loose also. loctite does the trick. if you cant find it. pm me a address. ill send you a tube of it.
Old May 26, 2012 | 08:06 PM
Diesel cat's Avatar
Diesel cat
thanks for the offer, but I finally tracked down some. like you I think my problem its the fitting vibrating loose.
Old May 26, 2012 | 11:09 PM
oldbird1965's Avatar
oldbird1965
I've never used that stuff, the O rings are the key to stopping leaks, IMHO.
whalebus2112
Aug 27, 2012 02:21 PM
brian42
16
Dec 21, 2009 07:28 PM
F250_
82
Apr 27, 2009 09:10 AM
kris-steve0410
Apr 23, 2007 08:41 PM
billet
Feb 9, 2005 10:01 PM
