Do you guy's know if a NP208 transfer case from a 4-speed manual transmission will also bolt up to a C6?
I wasn't sure if the bolt pattern was the same.
Also is a NP208 that bolt's to a C6 with a slip yoke rear output really that rare? i don't think they are but it is really hard finding one up here, They are all fixed yoke's Oh well
The NP208 will bolt up if it has the same bolt pattern as the current Transfer case. Ford had been using the circluar 6 bolt pattern with a seventh hole for locating pin for quite awhile, since the late 70's, but there is the chance it will have the odd bolt pattern. Crawl under your truck and verify your bolt pattern first then look for a transfer case that matchs up to your bolt pattern. You may even be able to use the BW1356 from a later model truck.
