First off I will say that I know that a 351w is a small block. I have been told that a 351c is the biggest of the three. I have also been told that a 351m and 351c are big blocks and I have been told they are all small blocks. So any light that you can shed would be much appreciated.
All 3 motors are basically considered small blocks. The M is the largest and heaviest, it's almost as big as a 460 with which it shares the bellhousing bolt pattern but it's really just a C with a taller deck. The 351M and 400 share the same block but the 400 has a longer stroke to give it the added CID.
The 302, 351W, 351C, and 351M all share the same bore size (4.00") and bore spacing (4.78"), which is probably why they are all considered small blocks.
BTW, the 351M and 351W crankshafts are different parts (try fitting a 351M crank in a 351W block if you don't believe me). They happen to share the same main and rod journal sizes, and the length of stroke (3.5"). The 351M crank also has a wider thrust bearing journal.
Sorry, I had heard that Ford just put a Wcrank in a 400 with new pistons to make the 351M to cover the great demand for 351 engines after the Cs demise. Dang, I guess that means I cant put a 400 crank in a 351w block! (Woulodnt that be cool!?)
as you read through a lot of the msg board, you will find that the 351m-400c/m are called small blocks due to bore spacing. basicly the 302-351w is one type and the 351c-351m-400c/m is another. the 351c is a hp monster that was discontinued in 1974. the 400c/m is the basis for the 351m, they are the same block, just different cranks. so if you want a 400 and you have a 351m, buy a 400 crank, you will have to change pistons as well, if i remember right.
