Windshield Leaking?
Old Mar 9, 2008 | 09:25 PM
jeff2761's Avatar
jeff2761
Windshield Leaking?
O.K. I have another question. I've got a leak in the cab of my 96 Ranger that I can only assume is from the windshield. I can't see any water coming in but the floor is always wet after it rains. What is the procedure for removing the trim so I can apply silicone? Thanks in advance for any advice.
Old Mar 10, 2008 | 08:41 PM
blue68f100's Avatar
blue68f100
Take it to a glass shop and let them reseal it. To repair it right the glass needs to be removed, frame cleaned. The the wind shield can be reinstalled with the urethane sealer.
I have a ultrasonic leak detector I use to locate leaks with.
Old Apr 15, 2008 | 08:26 PM
Cowboy34's Avatar
Cowboy34
do not use silicone to seal a windshield
Old Apr 16, 2008 | 09:58 PM
big poppa's Avatar
big poppa
Igot a leak in the left top corner of mine too. Only does it when it rains hard. I need a new windshield anyways. What the guys said above, take it to a profesional shop, for safety reasons.
Old Apr 16, 2008 | 10:04 PM
Cowboy34's Avatar
Cowboy34
i had mine taken out since it was leaking bad and found 1/4 rust hoels from left side to right side where the top of the cab comes down and starts going back to where the windshiled and rubber sets under the rubber and 1/2 to 3/4 holes in the top corners and above the doors on the cab from where the cab lights had been letting water in where they were cracked and not sealed the right way,now i have to find another cab
tasboj
Jun 8, 2012 12:26 AM
cheetoh
Oct 23, 2009 09:13 PM
VTRedwolf
Apr 27, 2006 08:05 PM
dorkpunch
Nov 11, 2005 05:28 AM
JuiceMonkey
Electrical Systems/Wiring
Aug 28, 2003 12:55 PM
