Aftermarket Products
Sponsored by: Worksport
LED tail lights
Old Mar 7, 2008 | 03:49 PM
silver lariat's Avatar
silver lariat
LED tail lights
I just took delivery of the chrome LED tail lights for my 06 Lariat. The upper half of the light, where normally the red bulb plugs in is filled with leds and there is a battery(?) attached to these bulbs. The battery has 3m tape on one side so obviously it is meant to be stuck somewhere? As there are no instructions with these lights, my question for those who replaced their OEM tail lights is, where did you stick the led battery?
Old Mar 7, 2008 | 04:25 PM
Beerstalker's Avatar
Beerstalker
If you can, please post a picture of the lights. I replaced my taillights with LED ones, and I did not have any kind of battery to hook up. I'm not real sure what you are talking about.
Old Mar 7, 2008 | 04:57 PM
silver lariat
This is a picture of the backside of the lights. Note the black plug at top (yellow arrow) is where normally a red/clear incandescent bulb would fit in the OEM lense. If these lights used the OEM bulbs the top bulb would plug in here. Instead, it appears you have to disconect a wiring plug from the OEM bulb fixture and plug it into this outlet (sorta like a trailer wiring plug). There are wires that run from the black insert/plug to the LEDs that fill the top half of the light.
Below this note the two wires that run to a black box with the red 3m tape on one side. This is what I assume is a battery or some part of the power source for the LEDs?
The white circle (noted by the blue arrow) is a whole where (again I'm assuming) the OEM back up light bulb simply plugs into place.
I've not removed the OEM light yet so I do't know what options are available to stick that battery? Posibly it can go right where it sits in the picture, but I won't know till I pull the OEM lense. Thought someone here might have had a similar experience.
Old Mar 7, 2008 | 06:01 PM
FTE Trigger's Avatar
FTE Trigger
That should be your "controller" (for the current lack of a better word).
It lets the LED blink at a normal rate. One of my boxes fell off (right-side) and the blinkers had issues maintain'g a consistent rate of flash after that period.
Also, I stuck the box just on the inside of the opening for the light (towards the back corner).
Old Mar 7, 2008 | 06:06 PM
silver lariat
Thanks. That makes sense. I realized after posting the pic that the power clearly comes from the existing wiring that plugs into the outlet at top of the light. So I was beginning to assume the black box then was essentially an on/off switch or like a 'flasher' for turn signals. I guess I'll just find a place to mount it when I pull the OEM lenses and look for somewhere with enough clearance so the new lenses fit properly.
Old Mar 7, 2008 | 06:33 PM
mhg's Avatar
mhg
the thing with the tape is most likely a resistor
this will load the turn signal circuit so the flasher will work properly
Old Mar 7, 2008 | 09:47 PM
Yonder's Avatar
Yonder
Which vendors tail light kit did you use?
Thanks,
Old Mar 7, 2008 | 10:03 PM
silver lariat
Autodynamic. Here's the link to the lights I selected.
http://www.autodynamic.com/detail.asp?PRODUCT_ID=FF04-LED-CLR-KS
GORDEN1234
2015 - 2020 F150
Mar 6, 2017 08:13 PM
johnday
1983 - 2012 Ranger & B-Series
Apr 20, 2013 07:30 PM
VONxRUBENxLA
Oct 19, 2011 07:31 AM
Supercab
Jun 20, 2010 08:05 AM
