Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior Guides
- How To Install Tail Light Bulb
Step by step instructions for do-it-yourself repairs
3157 LED bulbs for tail lights??
Looking at swapping to a GOOD QUALITY 3157 LED bulb for my tail lights.
I am wondering if anyone else is using these and what your opinion is and what type & color I should get.
I am seeing them listed with from 18 to 36 LEDs per bulb, and some suggest using a RED colored bulb (in my case) for the tail lights......is this right or would WHITE be better?? Thanks!
I was reading anouther thread recently about someone discovering that when they replaced a burned out 3rd brake light that the trans shifted better and the converter lock up was different.
Would I be OK then in just replacing my 2 tail light bulbs with the 36 LED ones and just leave a standard bulb in the 3rd light position?
I had a set of LED's in my tail lights. I bought what I thought were good ones, they were 32 or 36 per bulb and I paid way too much for them, even bought the right resistors. Got them all hooked up and they were nice and bright. They lasted about 5 weeks and the first one burned out, about 2 days later they other one burned out. I switched to a set of 3157 Silver Stars and I love them. They are just as bright as the LED's were and I've had them in for about 6 months now with no issues. They were a lot cheaper too. Just my .02....
not recon but similar I got em on fleebay 3 years ago and have not had 1 diode go out on the other hand the screamer led strip on my running board and the top- line of fires both have bad diodes as well as a cheapee 3rd brake light I returned.Btw napa sells the electronic flasher for the sd and it is a direct plug in but a little taller so the cover wont fit on and they work great with regular incandecent bulbs as well for around $15 around me.
on
i have all of the inside and out side bulbs replaced with LED's..there are no stock bulbs left...i also have a load resistor in each brake and turn lights in the rear..... the LED's i got from a local chrome shop for big trucks and have a life time warranty..they just came out with a 48ct bulb..ill be getting them for the front soon..they have a butter fly light that opens up 4 inches inside the light for the rear..gives it a recon look..there next on my list as well...i also got these chicken lights from them with the same warranty...i dont have pix of the rear but there is 3 red ID lights back there just like these..
the new tow mirrors have LED's as well..i got to get new pix taken..
Platinumpete: I actually bought the Silverstar 3156s for the b-u lamps, haven't installed them yet, I think I'll get the 3157s and call it good after all the stuff about the LEDs, relays, different flashers, ect-I think that will be fine for me.
Thanks to all that replied and for the pics!! -Rick
Patriotic Rottweiler
06-10-2018 09:54 AM
iRockFosgate
41
11-24-2017 05:37 PM
Jonnys.1991
02-22-2016 02:11 PM
