Steering Box Rebuild
Old Mar 7, 2008 | 09:57 AM
Voh's Avatar
Voh
After a ton of thinking and weighing my options, I think I am going to stay with the I-Beam and work on getting her tightened up. Starting first with the steering box. This steering box sure seems to be hard to find. I would like some input on rebuilding it or purchasing one already rebuilt. I found in on www.carsteering.com for about $350. Anyone know if that is a fair amount, too much, too little?
Any help would be appreciated.
Old Mar 7, 2008 | 11:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Voh
After a ton of thinking and weighing my options, I think I am going to stay with the I-Beam and work on getting her tightened up. Starting first with the steering box. This steering box sure seems to be hard to find. I would like some input on rebuilding it or purchasing one already rebuilt. I found in on www.carsteering.com for about $350. Anyone know if that is a fair amount, too much, too little? Any help would be appreciated.
Ask them exactly what was replaced in their "rebuilt" gearbox.
Both the steering shaft and worm and the sector shaft have been obsolete since Reagan was prez, so I doubt those two parts have been replaced.
What the usual replaced parts that will do the trick are, is the two steering shaft bearings (C2AZ-3571-A) and races (C2AZ-3552-A), the sector shaft bushings (some boxes have one, some two), the sector shaft seal (C7OZ-3591-A) and the gasket (C3AZ-3581-A)...that's it.
You can buy the above parts from NAPA for less than a C note, and fix the gearbox yourself.
All these parts are the SAME as the ones used in Ford passenger cars (60/64 Galaxies, 1962/70 Fairlanes, 1960/70 Falcons, 1965/70 Mustangs).
btw: your profile sez 1964, but '64's didn't have a Twin-I-Beam front suspension. The manual steering gear box uses different sector shaft bushings between 1961/64's and 65/66 2WD's. Dunno what yr you have, is the reason I didn't list the sector bushing part numbers.
Old Mar 7, 2008 | 08:52 PM
Voh's Avatar
Voh
I do have the '64. Do I have something that indicates that its a '65 some where? Thanks again for your help.
Old Mar 8, 2008 | 02:11 AM
NumberDummy
You stated in post #1 that you were staying with the I-Beam.
If you have a 1964, you do not have Twin I Beam front suspension.
You have the solid one piece front axle used 1961/64.
Twin I Beam front suspension was introduced in 1965.
Old Mar 8, 2008 | 03:36 PM
Voh's Avatar
Voh
Sorry. I see what you are saying. To be correct I am staying with the Straight Axle.
Old Mar 11, 2008 | 12:31 PM
bwilliams7527's Avatar
bwilliams7527
Bill,
What are the sector shaft bushing #s for a 66? Is this not complicated taking the steering box apart?
Old Mar 12, 2008 | 08:22 AM
NumberDummy
1965/66 F100/250 2WD
Two steering shaft bearings (C2AZ-3571-A)
Two races (C2AZ-3552-A) Bearing Industry Number = 8537 *
TWO sector shaft bushings (C1AZ-3576-B) Bearing Industry Number = Y1818 *
Sector shaft seal (C7OZ-3591-A)
Steering gearbox gasket (C3AZ-3581-A)
* I have a bearing industry cross reference book, but not all the Ford part numbers are listed.
All the parts store has to do, is look up the corresponding bearing for the race p/n of: 8537 (C2AZ-3552-A).
Blue7.3
Australia Chapter
Oct 2, 2021 04:07 AM
74F2504by4
Aug 19, 2012 10:07 PM
Encho
Dec 5, 2011 07:37 AM
75highboy390
Oct 13, 2011 10:53 PM
