Need help with Part ID
Old Aug 19, 2012 | 03:43 PM
74F2504by4's Avatar
74F2504by4
Question Need help with Part ID
Hello all,
I am slowly working on fixing all the issues with my steering, I have a rebuilt steering box and control valve to put in but I still have one more part. The steering linkage between the column and the steering box. I took pictures they are in my album called steering part. Specifically the end that connects to the steering box looks busted and has a lot of play, both rotational as well as forward and backward. The other end(column side) looks alright other than it looks like it could use a good cleanup. Is the steering box end rebuildable?
Or if someone has a part number, that would be great as I cannot seem to find one.
Ford Truck Enthusiasts Forums - 74F2504by4's Album: steering part - Picture
Old Aug 19, 2012 | 04:18 PM
mikeo0o0o0's Avatar
mikeo0o0o0
D2TZ-3B676-A Lower coupling assy., includes yoke and shaft assy.
No dealer or obsolete parts supplier has any.
Borgeson makes a replacement that does away with the lower coupling.
Borgeson Universal Company :: Ford Truck 1970-04 :: 70-'79 Full Size Ford Truck
Old Aug 19, 2012 | 04:35 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Mike, D5TZ-3B676-A replaced all the lower steering shaft & couplers used on 1967/75 F250 4WD's.
Many individual parts are available including the u-joint, unlike the 1976/79 couplers that are one piece assemblies.
There's no rag joint (1976/79 only), the coupler attaches to the input shaft of the gearbox with a clamp and thru bolt.
The whole enchilada is shown here in an exploded view: Illustration Section 35, page 14: 1973/75 F100/250 4WD
Old Aug 19, 2012 | 04:36 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Mike, D5TZ-3B676-A replaced ALL the lower steering shaft & couplers used on 1967/75 F250 4WD's.
Indiviual parts are available for1967/75, unlike the 1976/79 couplers that were one piece assemblies.
Oops!, thanks for the correction and update Bill.
Old Aug 19, 2012 | 04:41 PM
mikeo0o0o0's Avatar
mikeo0o0o0
D5TZ-3B676-A
Koehn Motors, Wellington, KS has 1 (620) 326-5915
Green Sales, Cincinnati, OH has 1 (800) 543-4959
Old Aug 19, 2012 | 04:50 PM
NumberDummy
Why buy the whole enchilada since individual parts can be bought for it? Might buy it cheap from Koehn, but Green Sales will want a kings ransom. Last MSRP was over 500 bucks.
Parts catalog pic ref edited into post 3.
Old Aug 19, 2012 | 06:35 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here is the exploded illustration from the Ford parts catalog.
Click on the .pdf link to view.
Old Aug 19, 2012 | 07:48 PM
NumberDummy
OP: Look at the parts catalog pic (thanks Mike): 3D699 is the clamp, 384192-S is the thru bolt.
If this isn't what you need, pick out the parts you do, post the numbers.
Old Aug 19, 2012 | 08:07 PM
74F2504by4's Avatar
74F2504by4
Thumbs up
Thank you, the pdf will be a great help. Will check about the pricing tomorrow. As always this forum is a great resource. Thanks again for the help.
Old Aug 19, 2012 | 09:00 PM
mikeo0o0o0's Avatar
mikeo0o0o0
(thanks Mike)
Not a problem Bill, glad to help.
Old Aug 19, 2012 | 10:07 PM
AnnLindel's Avatar
AnnLindel
51MHF5
Jun 10, 2013 09:33 PM
Jakegday
Aug 9, 2011 06:01 PM
Victor L
Jul 25, 2010 09:20 AM
loyal
May 22, 2009 12:48 AM
