2wd to 4wd
Old Mar 7, 2008 | 01:16 AM
1991 ford f-250's Avatar
1991 ford f-250
2wd to 4wd
my automotive class is taking a 1991 ford tempo, and making it off-road capable. is it possible to make it 4wd?
Old Mar 7, 2008 | 01:22 AM
khadma's Avatar
khadma
Carpenter Local 745
You might have to put the body on a Ranger chassis, but I am sure you guys could come up with another solution too. (convert the FWD to a RWD set up with transfercase and front driveline/axle).
Monster Garage made a 4x4 Vette, so I guess anything is possible!
Old Mar 7, 2008 | 01:26 AM
1991 ford f-250
would that be a realativley good fit or is there alot of work?
Old Mar 7, 2008 | 10:20 AM
blue beast's Avatar
blue beast
Take another tempo and chop the rear end of the one off and then graft the
engine, transaxle onto the rear of that one. Basically have 2 motors and two
tranmissions and two steerable axles!! A hydraulic setup for the rear steering
with a joystick control like a monster truck for spinning around in it's own
length maybe would be cool for tight trails(lock out at 15mph) A fly by wire
system would have to be rigged up for the gas pedal and use a couple linear
actuators or servos and a drive circuit that was hooked to the tachometer and
also feed by the speed sensor so you could synchronize the two motors and trans.
This would be the best way to go and just think if you blow up one motor you
can still get home just throw the dead one into neutral and drive out.
Extending the cv joints and lenthning the arms so you can remount the struts to
a lower spot and raise the ride height. A under carriage glide plate will help to get
across stuff instead of catching and stopping you. A roll cage put in after you
chop the back end off will protect you and help with chassis strength with the
graft.
91fordf150xltlariat
Jun 7, 2013 01:38 PM
ola1234
Jun 8, 2011 11:32 PM
walbert52
Jan 8, 2011 11:19 AM
ford12508
Jan 15, 2010 10:20 AM
Kongslibakken
1983 - 2012 Ranger & B-Series
Jun 16, 2006 03:25 PM
